I used a PT that was specced for a Princeton. It worked perfectly. Plenty of juice for the single channel but was able to avoid the higher voltagemartin manning wrote: ↑Thu May 30, 2024 1:41 pmOk, thanks. I made another revision, with suggested current production Hammond power transformers which include the bias tap, and left the original DR bias supply. I would have thought that without the normal channel 12AX7 you'd have a bit higher voltages on the V1 plates at the same 6V6 plate voltage.imo1 wrote: ↑Thu May 30, 2024 2:42 am I don’t have my notes in front of me(on tour) but the 6v6s were right at 420 and all of the preamps were pretty much right in spec with the deluxe schematic. So thinking 185-190 on v1, etc.
Nothing much higher or lower than spec.
My bias was taken off the hv winding and I implemented Merlin’s bias circuit, but used 10k pot and resistor.
Taming amp gain in single channel deluxe reverb build
Re: Taming amp gain in single channel deluxe reverb build
I believe you are correct & that EL84s do require less gain.
And I even made a mental note to that effect when I was mapping this out, but misplaced the note...or the dog ate it.
Personally, I like 15nf with 220k bias splitters, but use at least 5k6 for grid resistors.lonote wrote: ↑Thu May 30, 2024 2:29 pmOn my project, I was able to experiment some yesterday with knocking back the PI input using a voltage divider (the 220K + an added 250K pot to ground) & made some progress. Somewhere around 40K-60K on the pot was working well.
The comment about the .1uF coupling caps stands out though, as I have both the .1's & the 220K bias feeds in this circuit. Not sure how I landed on that CC value, other than auto-pilot.
As I am finding this one too bassy & will sub in some different CC's next.
Seems like integrating the Fender preamp to the EL84s is more fussy that I expected.
I have an amp on the bench that uses 47k grid resistors, which really seems to help with blocking distortion. this is a koch, which is known for its power and punchy response
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
