What do you believe regarding the sound of passive components?
If the component value is the same, is there any effect on the sound when using:
Resistors made of different materials?
45
23%
Old vs. new resistors of the same brand and materials?
9
5%
Different brands of resistors made of the same materials?
12
6%
Capacitors with different dielectric types?
46
23%
Different brands of capacitors with the same dielectric type?
14
7%
Capacitors with the same dielectric type but different construction?
22
11%
Check this box if you participated in the survey
49
25%
Total votes: 197
erwin_ve
Re: What do you believe regarding the sound of passive components?
Post by erwin_ve »
Here is a pdf and link to various articles and tests regarding different dielectrics vs voltage stress on capacitors.
https://linearaudio.nl/cyril-batemans-c ... d-articles
Erwin
bepone
Post by bepone »
Raja_Kentut wrote: Thu Feb 29, 2024 6:53 pm The graph fits not really in this context. Coupling capacitors are almost generally film capacitors.
almost :P in vintage fenders PI entrance cap is 500pF-1nF ceramic, and is by definition coupling cap.. also treble cap is ceramic and also can be considered "coupling" for frequencies above 1kHz :P so graph is ok
erwin_ve wrote: Fri Mar 01, 2024 10:58 amHere is a pdf and link to various articles and tests regarding different dielectrics vs voltage stress on capacitors.
Thanks, Erwin, I have saved copies of those articles but at that link they are all conveniently collected, and they are much cleaner than the ones I have.
I think most people accept that some types of ceramic dielectrics will add distortion, and that is reflected in the survey result here. Similarly, a large majority believes that resistor material makes an audible difference, but there IMO it's all about noise. CC are known to have a higher voltage coefficient, and some people point to that and say they will add sweet-sounding second harmonic (thanks, RG), but IMO it's negligible. I tried pulsing some CC resistors with high voltage using my tube curve tracer, and they don't look any different from MF. I've also measured the electrical properties of a handful of coveted MF's with an LCR meter, and they were all essentially the same.
erwin_ve
Post by erwin_ve »
martin manning wrote: Fri Mar 01, 2024 2:41 pm
Hi Martin,
Yes that link has great quality pdf.
My point was that there are measurable differences in capacitor dielectrics.
On the matter of resistors: I can hear differences between metal film resistors as plate resistors in a ODS circuit. I'm not here to argue whether I'm right or wrong. My goal is: why am I hearing this difference? I start to think it has more to do with the environment where a resistor is in, induced behavior maybe?
Just like putting outside foil of a capacitor on the low impedance side to prevent induced behavior. Not that a resistor has a outside foil. ..
Erwin
Metal film resistors are not all equal in noise, and this has been measured, and in fact the ranges of MF and CF overlap. Whether it's audible by humans is another question, since they are in general so much superior to CC that the difference between MF's seems negligibly small.
Last edited by martin manning on Fri Mar 01, 2024 4:42 pm, edited 1 time in total.
erwin_ve
Post by erwin_ve »
martin manning wrote: Fri Mar 01, 2024 4:37 pm Metal film resistors are not all equal in noise, and this has been measured. Whether it's audible by humans is another question, since they are in general so much superior to CF that the difference between MF's seems negligibly small.
That might be a explanation I won't rule out.
Sorry, had to eat a typo CF/CC above.
WhopperPlate
Post by WhopperPlate »
erwin_ve wrote: Fri Mar 01, 2024 4:23 pm I can hear differences between metal film resistors as plate resistors in a ODS circuit. I'm not here to argue whether I'm right or wrong.
Don’t worry , I will be their huckleberry…
it ain’t because you are tricking yourself into thinking they do , that much is certain for myself .
Erwin
Great points!
Charlie
WhopperPlate
erwin_ve wrote: Fri Mar 01, 2024 4:41 pm
If it’s the noise that’s the cause for the difference….then it’s audible
Charlie
These guys tried to measure resistor distortion, but apparently their results were inconclusive.
https://pub.dega-akustik.de/ICA2019/dat ... 001261.pdf
bepone
Post by bepone »
noise is the difference in sound between the resistor types? :lol: :lol:
i heard everything in my life.. but this.. :mrgreen:
erwin_ve
Post by erwin_ve »
bepone wrote: Fri Mar 01, 2024 6:08 pm noise is the difference in sound between the resistor types? :lol: :lol:
Did you read the post above yours from Martin?
The researchers considered the possibility of non linear behavior due to noise. Interesting stuff!
Electronic audio devices create a new virtual space.
Control the program, control the playback end of the rig (remote miced cab, even better; load box and direct) change your tone caps for the second pass. Flip the phase and fold the tracks to mono.
The difference is what is left in the monitors. You can bounce that and pick what is left to pieces with real tools that will show you exactly what changed and turn this thread into a graphics based argument.
I think induction is mostly to blame.
Caps, not resistors. You don't want to make yourself insane. Ok. Have fun.
bepone
Post by bepone »
erwin_ve wrote: Fri Mar 01, 2024 7:18 pm
Using one type of resistor you get sound like you are smacking metal can, and using other will result in warm, muddy blanket. And here people starting to speak that this difference is because of the noise between them ? (and tryin to explain with other people measurement which is having nothing in common with guitar amp) :)
bepone
Post by bepone »
Reeltarded wrote: Fri Mar 01, 2024 8:16 pm Caps, not resistors.
mostly correct .. but MF can also deteriorate sound
