Airline 62-9015-A
angelodp
Re: Airline 62-9015-A
Post by angelodp »
While I would not call it lipstick, its a somewhat satisfying restoration of what was a wreck. I have 16ohms on the speakers, not a match but not too harmful.
It's pretty stangy but the bass has some issues. I'll play it for now and come back in time to address the low end.
A
sluckey
Post by sluckey »
Actually looks good! Better than the original pic in the Monkey Wards catalog.
angelodp
Post by angelodp »
Thanks Man. I cannot say this cab is producing great tones, I may try a 12" 8ohm speaker at some point.
angelodp
Post by angelodp »
Much better
angelodp
Post by angelodp »
Hi, would this module work well in this amp? Can I grab the 5v from the rectifier circuit? If anyone has a schematic for this addition much appreciated.
A
sluckey
Post by sluckey »
Hi, would this module work well in this amp? Maybe
Can I grab the 5v from the rectifier circuit? NO WAY!!!
angelodp
Post by angelodp »
Ok, might you have an implementation for this module?
A
angelodp wrote: Tue Feb 28, 2023 12:50 am Hi, would this module work well in this amp? Can I grab the 5v from the rectifier circuit? If anyone has a schematic for this addition much appreciated.
There is a thread on this module. I recommend searching for it, maybe more than one. This is in my last amp build. The amp is about 90% complete has been sitting like that for 4 or 5 years. That's how old the thread is. I'm not quite sure why it remains unfinished. It is a combination of life got in the way and I made Swiss cheese out of the part of the chassis where that module needs to mount. I need time to finish it and a reinforcing plate so I can drill some more holes! You will need to build the circuit.
You might check with Lou Rossi to see if he still has boards for it. https://www.luigiretro.com/ There is more than one version of that module. Lou's board is for the 3H.
sluckey
Post by sluckey »
Several people over at Hoffman's forum have successfully used this module. Go search.
I'll bet there are some members here that have done the same.
angelodp
Post by angelodp »
Phil, tell me show me more, can you put up some aspects of your build?
Ange
