Spectrum Analyzer Test - 6PS vs 715P Capacitors
schaublin65
Re: Spectrum Analyzer Test - 6PS vs 715P Capacitors
Post by schaublin65 »
Hi,
please keep us up to date with this.
It's always cool to follow the fine tuning process. Spectrum analyser plots makes it even better.
Even if there is some debate about what they mean :D
Neat build too. See what you mean about the wire. Something a little bigger will be less of a hassle to work with long term I'd imagine.
Thanks for sharing.
Take care....
Littlewyan
Post by Littlewyan »
Yes the wire is just painful to use!
schaublin65
Hi
I'm building and fixing things for the last 33 years professionally.
One thing stands out for me.
You will seldom be sorry you bought the good stuff.
Take care..
Littlewyan
Well I found that out with the Silver Mica Capacitors. The ones I removed from the amp were cheap non branded ones I bought off ebay from Jellyfish Audio. I believe they are Japanese as I've seen them listed coming from Hong Kong. When I replaced them there was such a big difference it was like changing all 3 pre amp valves! Unbelievable. Cheap parts never again.
As for the wire I embarrassingly went by the photo which showed nice thick solid core wire. However if I actually looked at the measurement I would of known how thin it was. Its almost like telephone wiring! Hoping to get thicker stuff from RJ later in the month and will then rewire the amp. It has to look the part as well as sound good!
schaublin65
Hi,
the high end of the audible spectrum has a huge influence on the tone we percieve it seems.
In a superlead the ceramic 250pF seems a lot more aggressive than SM to my ears. Mine was factory built with two 500pF in series. I have yet to find anything that snarls like it.
"Man, if you think changing all the caps makes a difference you should try swapping the circuit out to my magic Marshall specs and stop messing with your amp for good."
Hopefully we will soon get the Magic :D
Please.
Take care...
Littlewyan
I've got a JTM1 that I built which uses 2 of those cheap silver micas and it has never sounded great. I've only got 1 of the good silver micas left so i'll change 1 and will see how it sounds. Tried looking for a 500pf ceramic on ebay but couldnt find any.
