I did not look at the schematic eitherLittlewyan wrote:
In Jazbo's voltage divider equation why was 18R and 39R used? Was 39R supposed to be 47R or something?
Low wattage Plexi
Re: Low wattage Plexi
- Littlewyan
Ah I see now it all makes sense. So for the 8Ohm Tap the 18R Resistor would be in parallel with 16Ohms, which gives 9R which is then in parallel with the 8Ohm Tap right? So if we had a 4Ohm Tap it'd be 9R in Parallel with that tap as well?
Guytronix Gilmore Jr.Littlewyan wrote:What Amp is this John? Sounds pretty good.
- Littlewyan
Sweet.
I think I get it now with the 18R Resistor. As its on the 16Ohm Tap the 8Ohm Tap will only see half of that and the 4R Tap a quarter. Is this correct?
