dorrisant wrote:Pin 5 of the rectifier is connected to the bottom terminal of the orange rectifier and also connected to the 80uf positive (+) can cap. The top terminal of the orange rectifier is connected through a 10ohm resistor to the negative (-) of the multi-cap can labled MC1.
Pin 2 is connected through the 100ohm resistor to the small rectifier negative (-). Pin 2 is also connected to the negative (-) of the above mentioned can cap as well as one side of the AC and filament tx. The positive (+) of the small rectifier is connected to V5-4 and V4-4 and filtered by the 80uf of the multi-cap can MC1.
Also, the negative (-) on neither the single cap can nor the multi-cap can are not connected to the chassis. Both are showing about 40k to the chassis. There are very few wires to the chassis ground as well as all of the pots and jacks.
Weird too, the bypass switch grounds out the signal at the output jack to the chassis. I don't think I've ever seen that before.
Sorry if I'm confusing you. I've never had to work with a supply like this... so your help is much appreciated!
Pin 5 and pin 2 of the rectifier tube are connected together and to the AC line hot (the side without the fuse and switch).
The neutral side of the AC line (with fuse and switch) is connected to the ground of the multi-cap can. I'll call that circuit ground.
So one side of the orange selenium goes to AC hot and the other side goes through a 100R to circuit ground on the multi-cap?
Then, I get confused: above and in your drawing you have both sides of the 80uF can connected to AC hot. Is it possible that the series chain of 10R, orange selenium, and 80uF are connected across the AC?
