Advice on best resistor and capacitor brands?
dreric
Re: Advice on best resistor and capacitor brands?
Post by dreric »
Cliff Schecht wrote:Using NOS electrolytics isn't dangerous if you know how to test them properly. I've never had an old electrolytic go bad on me after I tested it and verified it safe.
Cliff and other Testers
How you test and verify a cap?
Eric
David Root
Post by David Root »
Eric, there are e-cap testers that tell if it's over the hill and/or out of whack in ESR etc. See mine below.
They mostly test at about 150V which is not optimal, but mine seems to work OK.
Cliff Schecht
Post by Cliff Schecht »
Cap reforming according to my dad.
Here’s how to reform old caps (assuming they’re salvageable):
Take the unformed or old cap and measure its capacitance value with a Fluke DVM. Be CERTAIN that you haven’t charged the cap prior to doing this. It may read fairly close to its rated capacitance value but there’s a good chance that a lot of the dielectric has deformed and the cap will leak a lot of DC current when put into service.
Reforming the cap rebuilds the dielectric layer that the manufacturer established on the cap when it was new. Once reformed, the cap will not only have its rated capacitance but it will also leak very little.
To start: Put a resistor in series with the cap you’re going to reform. Choose the value of resistance to limit the short-circuit current to no more than a couple of milliamps (watch the resistor power rating as well, in case the cap is shorted and stays that way).
Next, hook the cap up to a variable power supply (minding polarity, of course) and slowly bring the voltage up to a value that’s a bit under the rated WVDC of the cap. IF you don’t have a variable high-voltage supply, you can hook the RC setup to a non-variable HV supply and just switch the thing on, although it’s preferable to apply the forming voltage slowly. Leave the cap hooked up to the HV supply for a few minutes and then check the leakage current flowing into the cap (measuring voltage across the limiting resistor and computing the current works fine). The cap’s leakage current shouldn’t be more than a couple of milliamps…some of the older ones may leak up to perhaps 10mA.
After the cap has sat under the charging supply for a while, disconnect the HV supply and then discharge the cap through a low enough resistance to run it down fairly quickly without making a lot of sparks while doing so. Don’t dead-short it to discharge it; it makes a lot of neat sparks and noise but the high surge current is really hard on the internal structure of those older caps. Then hook the cap up to the HV supply again (through the limiting resistor), leave it for a few minutes and then check the leakage current before discharging as above. Repeating this process a few times usually reforms just about any old cap that’s still in usable shape.
After the last forming run, discharge the cap one last time through a resistance and this time, place a shorting wire across the output for several minutes. A lot of electrolytics exhibit enough dielectric absorption to allow them to recharge themselves to significantly high voltages if left unshorted after being charged and that charge can fry your capacitance meter when you go to check the capacitance one last time.
So, after the cap has sat with the short across it for several minutes, remove the short and check the capacitance with your DVM. It should read within its tolerance limits. Since it’s been reformed, it won’t leak much either.
The term “dry” electrolytic is a bit of a misnomer. Modern, polymer dielectric electrolytic are truly dry in that sense but the older aluminum-foil and paper electrolytic all had some liquid in them. They were called “dry” since they didn’t have liquid sloshing about in them. Instead, the electrolyte was typically held in a paste form. If properly stored, some pretty old caps are still usable today. It’s easy enough to check the seals to see if they’ve broken or become embrittled and a capacitance/DC leakage test will also tell you whether they’ve survived or not.
If the electrolytic caps you have were used, then it’s probably best not to try to salvage them. The heat they endured for the years they were in service in tube equipment was usually enough to compromise their integrity or even kill them. NOS parts are worth trying to reform unless they’re really old (WWII or earlier).
Cliff Schecht - Circuit P.I.
dynaman
Post by dynaman »
Lazy, yet impatient guys like me just stick 'em in the amp and power it up slowly with a variac. There are surely better methods, but it's worked for me.
'67_Plexi
Post by '67_Plexi »
Cliff Schecht wrote:Cap reforming according to my dad.
This is great advice and absolutely the best way of acheiving a much better chance of reforming.
The last paragraph may be a little extreme with regards to guitar amps. The reason being most guitar amps are not used 24/7 in high stress enviroments, and in most cases they are powered up often enough to keep the caps healthy. This is the reason smoothing caps generally last so long. Clearly if you don't use an amp for a lot of years the opposite would be true.
Your Dad sounds like a knowledgable guy.
FYL
Post by FYL »
Handheld Tecpel LCR-612 meter for basic measurements (capacitance, ESR...), bench Heath IT-28 for leakage tests and reforming and Sencore LC53 for qualification - both go up to 600 V.
Another tip for old or NOS aluminum electrolytic caps is to submerge the sealed end (- negative end) in hot water at a level near the plugged end but not so high that the water can enter the cap there.
This helps the paste inside de-crystallize if the cap has sat on a shelf for a long time.
Let it sit there for a while until the water has cooled, then proceed with the reforming.
Here is a bit more information:
Apply the rated voltage through a 5W resistor. Anything from 20K-50K will do, as this is far from a precision process. The meter is used to measure the voltage drop across the resistor; when no current is flowing, there will be no drop. Obviously, when there is a large voltage drop (more than 20% of the applied voltage), there must be a significant current flow through the capacitor. The nature of a proper capacitor is to impede DC current flow, so when there is such flow, something must be wrong.
Note: Apply the appropriate D.C. voltage to the capacitor with a D.C. power supply. An old Kepco, Lamba etc. tube regulated lab power supply rig works great. Be sure to observe the proper polarity!
Within an aluminum electrolytic there is a large area of aluminum foil and an electrolytic paste. As the voltage is applied, current flows until aluminum oxide forms on the surface of the foil, because aluminum oxide is a very good insulator. If excess voltage has been applied during the electrolytics lifetime, it is possible that tiny welds exist which the oxide insulator cannot separate. When that occurs, the capacitor cannot "reform", and should be discarded.
If the amount of current flow (voltage drop across the resistor) is great initially, that is not a problem. If it doesn't start dropping within five minutes of application of voltage, a definite hazard exists. The current flow indicated that energy is being dissipated within the capacitor, in the form of heat. Excess heat may "pop" the electrolytic, causing the paste to spit out...a threat to eyes and paint.
It's also worth remembering (one forgets only once) that a good capacitor will store its energy for quite a while, and discharge it through the hand when picked up. It's smart, then, to discharge the unit deliberately, through a resistor equal to about one ohm per volt of charge.
statorvane
Post by statorvane »
Whatever type of non-polarized capacitor you prefer, check this out.
http://www.youtube.com/watch?v=VP6ZIHXq6Yg
I would think the orientation can be more important than the brand and/or material composition.
Some say with the modern film caps this is less important than it used to be.
A lot of guys build their amps never orienting their film caps unless there is an actual line show it.
I tried what Gabby is doing there and I couldn't get it to work for me.
