pullshocks wrote: ↑Mon May 17, 2021 6:46 pm
Thanks for posting. Enjoyed the Soundcloud.
Interesting that you are using an xFBxxx tank, as I am. I ordered the "correct" xEBxxx, it should be here in a few days.
I don't really see how xEB is "correct"?
Swart amplifiers use very similar (if not the same) reverb arrangement with xFB, Traynor (albeit EL84 driven - same principle) and Magnatone (early models with single triode of 12AU7 driven) to name another few
I didn't run the calculations, but based on these - xFB seemed like the right one from the beginning, hence that's what I ordered and installed. And it sounds quite right to my ears.
Could you elaborate on your grounding scheme? I found it hard to pick it out in the photos.
I would be sincerely amazed, if you would in this mess (PR friendly statement would be - built in the best yesteryear traditions of Magnatone, Supro, etc...)
The facts are that it sounds great and is dead quiet.
Here it is in short:
Reverb driver/recovery to the common (pots) bus and input ground.
1st, 2nd and PI stages to the respective tag strips' chassis lugs.
Supply to its own tag strip chassis lug (and HT center tap goes there).
I also used the DC filaments supply for the preamp tubes and referenced it to (a separate strip chassis lug) ground via two 100R resistors (prior to the small DC rectifier, filaments transformer secondary CT is not connected).
Hope that's of some use.
Will be looking to post some single lines samples as well. To me, it's more important how the sound plugs into a full piece, but I often find that some may see single-line samples more valid.
Niki
