Break that new speaker in for like 8 hours
With some low voltage 60 hz ac like from a wall wart.
Do you have a veriac to use ?
Fuzzy sound
Re: Fuzzy sound
Re: Fuzzy sound
Hello --
Reading quickly through your circuit description it seems all of your interstage coupling capacitors are 0.01uF, which is reasonable for a guitar amp where 80Hz is an adequate frequency to begin reducing signal. For hifi tube amp designs it's typical to use 0.1uF or at the very least 0.05uf. Frustrating to change out but believe you will get closer to the bass performance you aspire to. The description is unclear on the nature of your output transformers. Should these be too small that could also be limiting your low end.
Best ..
Best ..
