Ultimate Hammond Conversions thread
Kczech
Re: Ultimate Hammond Conversions thread
Post by Kczech »
I spent 5 mins going over the chasis looking for a AO# and couldn't locate anything. The underside has 13 written with a green marker.
sluckey
Post by sluckey »
I've never seen that one. The PT and OT are the same as found on the AO-29-13.
thetragichero
Post by thetragichero »
measured and calculated these awhile back
ao-24924 output transformer 7k4:8
ao-24110 power transformer
red-red/yellow-red 350v-0-350v
brown-green-brown 6.3vct
yellow 5v (3A since this runs a 5u4)
shame didn't come with the ao-43 chassis that was likely in the organ with it. two ecl86 tubes are fun to mess with (especially if you add another 12ax7)
sluckey
Post by sluckey »
thetragichero wrote: Fri Jan 01, 2021 10:29 am shame didn't come with the ao-43 chassis that was likely in the organ with it. two ecl86 tubes are fun to mess with (especially if you add another 12ax7)
The AO-43 uses 6BQ5/EL84. The PT is AO-24157-1 and OT is AO-24158-0.
The AO-44 uses ECL86/6GW8. The PT is AO-24956-1 and the OT is AO-24158-0 (same as AO-43).
thetragichero
meant 44, typed 43. hammond's numbering convention seems about as useful as marshall's
dragonbat13
Post by dragonbat13 »
Amp and preamp out of L74 Baldwin. Have all Baldwin tubes. All kinds of extras. Fused leads off power transformer. Flyback diodes on the OT.
Mark Clay
Amature/Hobbyist/Electronics Hoarder
ok_state_blues
Post by ok_state_blues »
Hammond S-1 to 5E4A. Thanks for all the knowledge on here. I didn't want this sticky to die
Colossal
Post by Colossal »
ok_state_blues wrote: Sat Jan 22, 2022 2:51 am Hammond S-1 to 5E4A. Thanks for all the knowledge on here. I didn't want this sticky to die
Sweet amp, man. I have heard some seriously good conversions using Old Hammond iron.
ok_state_blues
Colossal wrote: Sat Jan 22, 2022 1:21 pm
Yes it works great as long as you can tame the voltage. Captain foldback has been a very valuable resource. Now I know what to do with the field coil PT's!
ok_state_blues
Hammond AO-14 to Matchless Lightning.
Cartman
Post by Cartman »
Have any of you Hammond builders run these amps with a mis-matched speaker load? If so, were there any negative effects noticed? I have two AO-43 and one AO-35 converted to circuits for guitar, and I always use a 8 ohm speaker load. Just wondering if these would be fine with a 4 ohm or 16 ohm speaker load. I know that Hammond iron is known to be pretty robust.
sluckey
Post by sluckey »
I have run the AO-43 OTs with 8Ω and 4Ω speaker loads with no ill effects.
Cartman
Post by Cartman »
FWIW, I tried both of my AO-43 amps through 8 Ohm and 4 Ohm cabs. A single speaker at 8 Ohms and a pair of the same speakers in parallel at 4 Ohms. They both sounded fine with either load, and the transformers did not get hot. I did notice a slight drop in volume at 4 Ohms. I guess that is to be expected if the OT is designed for 8 Ohm load.
maxkracht
Post by maxkracht »
Here's my latest Hammond conversion. AO-43 to something resembling a modified Princeton reverb with a cathode biased 7189 back end.
 I lifted a transformerless reverb driver from Merlin’s site and the LND150 recovery stage (I think) from a fx loop schematic? Cant quite remember where I stole it from or who to credit. The reverb switch is backwards, down being on. Couldn’t figure out how to easily reverse it without making the wiring more of a headache. There’s a foot switch anyway… TMB tone stack, no negative feedback, Vox cut control (sparkle). Planning another with a master volume, neg feedback, and no cut control.
I’m pretty happy with the layout, aside from the upside down reverb switch. Kept the original PWR and REVERB SW. markings/functions. Used every original eyelet and tag strip (excluding grounds) and only one added turret attached to the treble pot. I kept the reverb choke in place and added another dropping resistor before it for good measure. The amp has a very low noise floor and sounds pretty good to me. Reverb is very surfy. I would be happy to hear suggestions for improvements if anyone has them. Not all of the values on the layout are exactly what I ended up with. I tend to change my mind on details mid build.
I made a time-lapse video of this and a handful of other hammond conversions I’ve done this year if anyone is interested.
dragonbat13
That's a very nice conversion. From what I've heard conversions are difficult. Yours makes it look even more challenging. If I could ever get caught up I want to mess with my Baldwin.
Mark Clay
