Yeah, it's strange that some of the Metro amp fellas install a carbon comp kit in their builds.
But like you said, I don't believe Marshall ever used them.
They had carbon film which is much more stable.
The early marshall amps had CC resistors, or a mix of them in the amps.
No matter what resistors you use, unless you use some exotic pots,they are a variable resistor with a carbon track.. Some may ask if pots sound different..
I don't think enough tests were tried with cc resistors. And the one thing that is posted, always seems to pop up as being the bible of CC resistors. I do think they do produce a smoothness or have an effect on the sound.
Do they drift in value, yeah,sometimes. Do they make noise or go bad, yeah sometimes. But other times i have seen them in amps from the late 40s that are as quiet as any,and measuered they haven't drifted in value.
Alot of times amps or resistors stored in basements or left in trunks of cars,or even the location,if there is a lot of humidity. These are the amps that you may see have more problems.
And these amps may also have the same issues with tube contacts needing cleaned etc..
I've worked on a lot of old amps, and any others that have worked on old amps, may find the coupling caps going bad or needing changed,more than the resistors.
Many to almost all of the old amps used CC resistors,because thats what was available at the time. And if one clones an early amp,they want to use the same type parts. Not everyone,but some.
yes i have changed bad CC plate resistors in amps,also cathode,or grid stoppers to what ever section. And i've also done the same in amps using other types of resistors.
I think no matter what you hear or see posted,use what you like. Some values of the CC resistors are now getting harder to find,and also the price of them is really going up. And the CF or MF etc.. are not as expensive.
I just always hated to see people give the CC a bad name,and just passing on what they have read or someone told them on the net.
Some may say their isn't any mojo in parts, but knowing what or where to use certian type of parts can and will have mojo effect on the outcome of the sound. Usually a new builder may get 'lucky' and this happen. But its usually knowing what to use,and where to use, by years of experience listening and experimenting.
A scope may not always show or tell you how something sounds to the ear. If its a pleasing sound, or non musical as i call it to the ear..
