I certainly don't want to step on anybody's toes, nor hurt any feelings, as I've come to the conclusion several ears ago, related to HiFI, that it is quite difficult to discuss a personal opinion. If someone claims to hear a sonic difference between this and that, who am I - or we - to say otherwise, particularly when we are not there to hear the same thing , - or not.
From an engineers POV, though there are some good contradictions in several of the referenced links, some obviously based on hearsay and some on the typical urban myths among non technical inclined musicians. Quite a lot of this has it's parallell in the HiFI community.
Some of you may not have seen this - but this is the average engineering POV:
First- resistor noise is mostly dominated by thermal noise - aka Nyquist or Johnson noise - all the same. Any resistor - of any type and value- will produce a noise voltage of U=sqr ( 4kTBR ), where k is Boltzmanns constant, B is signal bandwidth and R is your source resitance.
If we set the bandwidth of a typical guitar amp to 10 kHz, an amp with 1 Mohm input resistance will thus produce an equvivalent input noise voltage of appx 13 uV. Lowering the input impedance to 10kohm will lower the input noise to appx 1.3 uV. Given an average 50W guitar amp having a total voltage gain of 500-1000 at full blast, and allowing extra gain for overdrive, a maximum noise voltage of 13 mV should be present at the output - barely audible at close range. But remember - this is the equivalent input noise level. All additional stages in the amp will add their own part, but at a lower and lower level as you approach the output. The general consensus is that your first stage of amplification always sets the signal/noise ratio - unless there's something seriously wrong underway.
This is a theoretical view - It would be quite interesting if some of you would hook a scope at the output and measure the peak noise voltage of a good, quiet amp.
The Audio Express article seems to exaggerate the difference between CCs and metal films. There is a difference, but experiments have shown that the length/diameter ratio plays a role here. CCs seems to have more 1/f noise, but mainly at subaudible frequncies . See links below.
And- resistors don't have shot noise per se. This is a kind of noise usually associated with semiconductors and tubes.
Now- tube amplifiers are usually high impedance devices, which by nature are susceptible to noise problems. Even though, if severe noise is present in a guitar amp, my suggestion is that there's something wrong, - components, layout..... bad layout can be a source of local instabilites by stray capacitance, - enhanced by the inherent high impedance.
As I've already stated, I'm new to guitar amp building and design, but not to electronics. I read the statements and try to evaluate my own opinions. Time will show if I'm wrong, as I'm sorting out parts for an amp for my son... Xicons and Orange drops, I have quite a collection of NOS parts, too. Metal films, CCs, carbon films, wirewounds and oxide resistors...
A few links from non guitar related sources - more of an engineering view to the problems.
http://en.wikipedia.org/wiki/Thermal_noise
http://www.analog.com/en/amplifiers-and ... s/fca.html
http://www.analog-europe.com/howto/2122 ... SCJUNN2JVN
And finally - the Jung and Marsh Capacitor Bible
http://www.reliablecapacitors.com/pickcap.htm
Best regards
