Valvetronics 100.
Pr@
back covers.
Post by Pr@ »
The important rear covers give a certain amount of its tone, I tried the sound without them on and it wa a bit thin (Basless) sounding.
Wheres the fire extinguisher John?
Pr@
Old and new.
Post by Pr@ »
Heres the old Vox box and the new one, compare the size.
The weight of the old Vox box when loaded with amp and speakers was 64 pounds, the new apeakers and box weighs in at 41-1/2 pounds. No more straining up stairs and across the parking lots, gigs are more fun for sure!!!!
The sound is a little tighter, a little less basey, but with what "feels" like far more "solid punch", this hits the front row of seats pretty hard (so they tell me) and I like it!
Pr@
Handle.
Post by Pr@ »
The carrying handle on this is a 1 inch by 5 inch hole cut into the centre of the top pannel, just slide the fingers into the hole, bend them and lift, this leaves the top surface of the speaker nice and flat to stand you head or?? on. the parallell jack sockets are inside and when plugged in, the jacks do not protrude outside of the box, so they dont get snapped or bent when parts of the drum kitt (or the drummer) hurtle past.
I gotta make a box for the amp part of the VT 100 next, will start a different thread for it.
Thanks guys for the feedback on my sorta silly but usefull project.
Like I said, I can swap all the parts back to the old box if I get tired of this configuration.
Pr@
Happy together.
Post by Pr@ »
Matching finish (sorta different) as well as a real good sound adds to stage pressence (visual "and" audio impact), stage pressence is a big part of todays road to success! "Where did I go wrong".
Pr@
Check yours.
Post by Pr@ »
When messing with the black and white speaker wires in my combo, I found that the white speaker wire, in several parts of its almost 12 inch length, was down to only one strand, is this to act as a fuse (2 amps my guess), or a faulty batch of speaker wire.
Check yours!
