Hello Guys,
Here is an experiment that you can try that will definitely put things into perspective as regards to the trust you CAN have on your tools.
Pick any two 1 Ohm resistors labeled with 1% tolerance. Connect them in series to a 200mA current source (*more on the current source below...). Now measure the voltage at the top of this 2 resistors string against ground and let's call this Vtot_1. Then measure the voltage in the middle of this two resistor string and call this Vmid_1. Lather. Rince.
Now _swap_ the two resistors. Repeat the measurements. Let's call these new Vtot_2 and Vmid_2 for good measure.
I bet that you will find interesting results! Hint: Vmid_2 and Vmid_1 should be very similar. Also, Vmid_x should be very very close to the half of Vtot_x...
Do this with, say, a Fluke21, on the 300mV scale. Mine is a 15 year old unit, and is still worthy of this experiment... You will find that 1% resistors are usually called 1% resistors for a specific reason
. You should also have a hint as to why a lot of folks use a _voltmeter_ to _compute_ the total cathode current passing through 1%, 1 Ohm resistors in an otherwise very fine tube output stage circuit!
Google for "kelvin measurement" or look at these:
http://www.cirris.com/testing/resistance/fourwire.html
http://www.allaboutcircuits.com/vol_1/chpt_8/9.html
Have fun !
Some important details:
*Note on the "current source": pick a good power supply you have and select a resistor R that will safely pass 200mA between Vsupply and ground (power wise, I mean, and you guys know how to deal with 300Vdc circuits, so I won't comment on the lethal voltage thing). Verify that Vsupply/R is about 200mA and you should be fine. Now connect the supply across the series combination of R and the 2 other 1 Ohms resistors. That's right: one supply, R, the first one Ohm resistor, The second One Ohm resistor, then ground. Make sure that the 2 one Ohm resistors are connected on a very short path (twist them half a turn and solder them together) and make all the measurements directly on their legs.
**Note2: BTW, sticking a 1K resistor from a 200Vdc preamp supply is NOT a good idea since it could draw up to 40Watt!!! So start with something smaller supply wise. Batteries are fine, as long as you know how to safely fuse the thing and measure quickly before the batteries die out... Remember, we want 0.2A in the dual 1 Ohm series resistor string to get the scale going on the DVM... You can use less current, but we want to play on the top of the 300mV scale to get good numbers to play with. We also want to stick to the same scale for all measurements... Turn that autoscale _off_ !!!
