6V6 tonal character.
bepone
Re: 6V6 tonal character.
Post by bepone »
Tobyk wrote: Wed Aug 30, 2023 9:40 am
bepone wrote: Sat Feb 25, 2023 4:07 pm
TUBEDUDE wrote: Fri Feb 24, 2023 9:29 pm IMHO the cathode biasing and a feedback free power stage are keys for magical tone.
no feedback amp=excessive highs, i dont know a person who wants this
This only applies to SE though, no?
to tubes with hi internal resistance, small pentodes per example , SE small tubes etc..
PP can be made also without feedback but speaker impedance defining sound, must be straight line, or very slight raise,
in any way tube internal impedance must be lovered somehow (nfb, cfb, shade, triode mode etc)
TUBEDUDE
Post by TUBEDUDE »
All valid tools to shape tone. I just prefer any feedback source not run through a transformer.
TUBEDUDE
Post by TUBEDUDE »
The late cut and cathode feedback are good. Sometimes a Zobel, depending on speaker characteristics. But when I'm looking for a bluesy tone I usually like a more compressed and slightly distorted tone. In my builds it comes from an overdriven 5879 in the hot channel. A dirtier signal seems less sensitive to global feedback than a cleaner signal.
Tobyk
Post by Tobyk »
TUBEDUDE wrote: Wed Aug 30, 2023 6:47 pm The late cut and cathode feedback are good. Sometimes a Zobel, depending on speaker characteristics. But when I'm looking for a bluesy tone I usually like a more compressed and slightly distorted tone. In my builds it comes from an overdriven 5879 in the hot channel. A dirtier signal seems less sensitive to global feedback than a cleaner signal.
Yes, I dig a compressed tone too.
This is my kind of tone:
https://m.youtube.com/watch?v=JajP0b8Ah ... VlcyB0b25l
It’s a Gibson Falcon, which is a 2x6V6, with tiny OT which generates that compression.
But my quest is to get that same tone from a SE with a cathode follower or perhaps a pentode (like you use) in a later gain stage. Have you tried both ways?
Tobyk
Post by Tobyk »
When you say cathode feedback do you mean an unbypassed cathode resistor or plate to cathode feedback?
TUBEDUDE
Post by TUBEDUDE »
Feedback around the tube, but cathode degeneration is valued also. I also will take feedback from the output of a 2 stage preamp amp and send it to the first stage.
I love your Falcon, I had a '60's GA-17RVT it didn't sound that good though.
I've only designed 5 or 6 SE amps, and they had no hot channel. They were meant to operate relatively clean, so I can't speak to that. Most of those had some power supply browning of the output if chosen to play at high levels but clean was mostly the goal. In one I used a 6DQ5 SE for ~15 Watts. It got stupid loud cleanly.
If you can find a copy of The Radiotron Designers Handbook Vol. 4, there is plenty of inspiration for spectrum shaping and feedback applications.
Tobyk
Post by Tobyk »
TUBEDUDE wrote: Thu Aug 31, 2023 1:16 am Feedback around the tube, but cathode degeneration is valued also. I also will take feedback from the output of a 2 stage preamp amp and send it to the first stage.
Thanks! I ment if you compared pentodes to cathode followers for compression. Not a lot if tiny OT’s on the market today. Also, if you don’t mind telling, what setup you use on the pentode screen for compression?
TUBEDUDE
Post by TUBEDUDE »
No I haven't experimented with an AB comparison. I like overdriving the 5979 to get a true pentode distortion, that's where the compression occurs, biasing the pentode for operation just below the knee.
