Exactly. In my redraw of the Eagle Supre, I labeled the first used power node as node "B" to highlight that point, that node A is not used in a CLC filter. Or at least if it was, it would not effectively be "CLC filtered" and likely be noisier. Thank you for clarifying that.pullshocks wrote: ↑Thu Feb 03, 2022 11:48 pm Note that in the AX84 schematic, nothing is connected to B+1. As I understand it, the first filter cap (C1) and the 100 ohm resistor (R1) gives an "extra" stage of power supply filtration, to offset the inherent hum of the SE power amp.
SE Circuits
Re: SE Circuits
Just plug it in, man.
Re: SE Circuits
oh yeah, whoops, I missed that.
https://tfrelectronics.com/
https://oshpark.com/profiles/TFRelectronics
pullshocks
Re: SE Circuits
Looking forward to seeing more about your project as it develops.
Right now for a preamp I have the clean channel from Tone King Imperial schematic that has appeared on the internet, but with a mid control added. I do not have negative feedback on the PA. May try that in the future
Re: SE Circuits
Hi Dave, are you saying that Viperdocs schematic would work out? I have a donor amp that is prime for another Supre Eagle. If you recall I built one in the original iteration, and it was/is a fine amp. In the donor amp I have it has all the necessary elements and a choke to boot.Not sure if the choke is correct for the project. Just wondering if the schematic looks good to go?
Best Ange
Best Ange
Re: SE Circuits
Just a note on this terrific amp. The layout shows the 1K 3w R going to pin 6, with the connection to the dropping string at pin 4. I think that wire should be at pin 6.
