Stevem wrote: ↑Sat Sep 08, 2018 10:07 am
My feeling on this whole thing is that from what I have heard there's a point where a greater more accurate balance makes the guitar sound too sterial even for clean tones.
Some minor phase canceling works for me guys what can I say?
That may well be. Music is and should be a personal and emotional experience. Technical accuracy may not be ideal. However, once you know how to make something very accurate, you also know how to make it inaccurate, and you generally know how to make it inaccurate in the way and amount that you'd like.
The long tailed pair PI is a special case of a differential amplifier. The general idea is that the current for both sides is set by the resistors in the cathode circuit and is kind-of a fixed amount. The "long tailed" part of the description comes from the idea that if the voltage across a resistor doesn't change much, neither does the current. So the common resistor is made "long" - a big resistor with lots of voltage across it, and relatively little voltage change. Using a resistor means that there is still some current change, especially on big signals. The current change on big signals affects both halves of the diffamp. It's a kind of common mode gain change. This effect is used with transistor diffamps for out-and-out gain change in multiplier circuits.
For a single-side-driven differential amplifier, you can think of the setup as a common-cathode, ordinary tube gain stage at the input, with the second stage being a common-grid amplifier driven by the cathode of the first stage. If the transconductance of the tubes is high and the impedance at the cathodes is high, you get nearly the same gain from the common cathode input stage and the common-grid second stage. However, tubes being tubes, the transconductance is never high enough to make this work perfectly, and the gain of the second, non-input stage is a bit lower.
You can make up for the lower gain by diddling the plate resistor values. That's why many long tailed pair PIs have an 82K plate resistor on the input and highest gain side, and a 100K on the plate of the second half. It helps equalize the gains, and restore some balance, if a bit crudely. And this tells you one way to make the sides of the plates NOT balanced: un equalize the plate resistors. This works even if you have theoretically perfect tubes or high gain solid state devices. You can even make it dirtier by making one or both plate "resistors" have non-linear things like diodes and such attached to make it really unbalanced and dirty in ways that you choose.
Putting a constant current source in the cathodes makes the balance of the LTP better because it raises the gain from the input to the cathode of the input stage more toward unity, and does not eat signal from the input side cathode, leaving more for driving the common-grid second stage. It also forces the sum of the two halves to be truly constant, so any increased current from one side is truly taken out of the other side. Again, you can mess with this by making the constant-ness of the current source on the cathodes be less constant.
I'm a techie - it makes me feel good to know how things work, and how I can tweak them.
Mark Twain
