New Octal Build
Re: New Octal Build
Looks excellent
Re: New Octal Build
Beautiful!
fusionbear
Re: New Octal Build
Thanks for the kind comments. I already made some minor changes to the circuit. I adjusted the B+ string value between the choke and B2+ (Screens) and I changed the cap going to the Treble pot from 3.9n to 2.2n. The James tone stack is really fun to play with and the mid shift, while subtle, really makes a difference in all the right ways. Really happy with the amp. This weekend I will get an opportunity to play it louder and see how it does cranked up... So far I am really pleased with it. As I was playing it this evening, I was amazed and the delicious bloom and sweet feedback it would get at a reasonable volume... I haven't measured the output, but I am guessing that it is about 30 watts. The volume seems to max out at about noon on the LAR/MAR MV and just gets thicker from that point on.
Here are a couple of parting shots:
[IMG:640:480]http://i169.photobucket.com/albums/u223/fusionbear/Wreckish%20Octal%20Build/IMG_0797_zpsbuolfqv9.jpg[/img]
[IMG:640:480]http://i169.photobucket.com/albums/u223/fusionbear/Wreckish%20Octal%20Build/IMG_0789_zpsyj1fkd7h.jpg[/img]
They don't show the changes I made, but you get the point. Honestly, this is the best sounding amp I have assembled for myself... I know there is no best as we all hear things differently, but for me, this is tops...
Learning to learn...
fusionbear
Re: New Octal Build
final adjustments to the circuit pics:
This shows that I added one more step down resistor for the Screen supply:
768]http://i169.photobucket.com/albums/u223/fusionbear/Wreckish%20Octal%20Build/IMG_0078_zpswozxelgv.jpg[/img]
I ended up with a 24pf fizz cap:
768]http://i169.photobucket.com/albums/u223/fusionbear/Wreckish%20Octal%20Build/IMG_0080_zpsayrtq1e6.jpg[/img]
This one shows the change from a 3n9 to a 2n2 on the treble control and a 100k grid stopper on V2b from 56k:
768]http://i169.photobucket.com/albums/u223/fusionbear/Wreckish%20Octal%20Build/IMG_0070_zpsgfpp42er.jpg[/img]
fusionbear
Re: New Octal Build
Question: Any issue with putting the so-called "fizz" cap right before the inputs of the power tubes? Let me know...
- dorrisant
Re: New Octal Build
Does it sound good? I don't know of any I'll affects but seems that you could get more drive out of the preamp by leaving the treble turned up there and cutting it out in the PA. Kinda like the cut control in the Vox or Rocket circuits. In those, I turn the treble up and notice a hotter signal... Then cut out some with the cut control to make it play nice. Don't know if that helps but there it is.fusionbear wrote:Question: Any issue with putting the so-called "fizz" cap right before the inputs of the power tubes? Let me know...
We need a well organized gallery of your builds. I know that neatness during a build facilitates easy modding and troubleshooting. Newbies and veteran builders can appreciate and learn from your builds... I do.
fusionbear
Re: New Octal Build
Le clip:
https://www.youtube.com/watch?v=u0QRkuGIhQU
Small disclaimer. V1 started going microphic on me right as I started making this clip.... oofta! I will make another clip once I get more tubes....
BTW, anybody know where I can get those rubber rings that go around tubes? I think I can make this one work with just that....
Re: New Octal Build
That sounds killer! Auto parts store maybe for some silicone orings
Re: New Octal Build
Great job Carl.
You & Tony have me wanting to build sumpin all octal with those strips.
The sickness is upon me - bad.
Very Cool.
Very Cool.
Why Aye Man
fusionbear
Re: New Octal Build
Not quite satisfied, I changed things up a little and now I am content... at least for a few hours... LOL...
1. I removed the mid-shift as its range was more limited than needed, so I replaced with a resistor value that I thought was appropriate.
2. I also reduced the value on the Treble pot leg to ground from 1000pf to 500pf. This gave me a little more upper mids. Also went with a 3.9n Treble cap.
3. I added a cut circuit 500k/390pf
4. I reduced the value of the Treble out resistor to input grid of V2 from 20k to 10k.
Here is Samson again:
768]http://i169.photobucket.com/albums/u223/fusionbear/Wreckish%20Octal%20Build/IMG_0188_zpsrlhxboio.jpg[/img]
Once I get my new tubes and silicone rings, I will make a new clip. I am even happier with the result...
Re: New Octal Build
The first clip you made was pretty great, ridiculous sounding hard rock amplifier! I'm really looking forward to the next one w/latest improvements.
It may be faux pas to ask (?) but this amp seems influenced by the Red Iron T-Rex you recently posted info about/clips of. Did you incorporate a choke input filter on this amp a-la T-Rex?
fusionbear
Re: New Octal Build
No, standard config. Also, my voltages are different. Mine is closer to an express...WRC34 wrote:The first clip you made was pretty great, ridiculous sounding hard rock amplifier! I'm really looking forward to the next one w/latest improvements.
Re: New Octal Build
Thats a cool looking build and the clip sounded great!
I'm confused about the values on the treble control though.
you say you've reduced the cap to ground to 500pF and have used a 3.9nF treble cap, the way I'm reading that is kind of 'upside down'. Isnt the smaller cap usually feeding the pot and the larger value on the ground leg?
Cheers
Shane
Cheers
Shane
fusionbear
Re: New Octal Build
shane wrote:Thats a cool looking build and the clip sounded great!
you say you've reduced the cap to ground to 500pF and have used a 3.9nF treble cap, the way I'm reading that is kind of 'upside down'. Isnt the smaller cap usually feeding the pot and the larger value on the ground leg?![]()
Cheers
Shane
This is a James Tone Stack. The 3.9n feeds directly from the wiper of the gain. The higher the value, the more overall content. Too high and it adds bass. It is basically a coupling cap... Play with the Duncan tone stack program.... Really fun to see how playing with the different values affect the frequency response...
Re: New Octal Build
Carl,
How is the James stack working for you? I am thinking about using the James for a clean build. What value did you settle on for the mid resistor? Did you find the mid control to be of little value?
Great looking amp and it sounds killer.
