dc for the heaters
dorrisant
Re: EASY
Post by dorrisant »
surfsup wrote:
ampdoc1 wrote:Check it on my current build. (Blue Caps mounted on the FWB and the module mounted thru the FWB screwhole to the chassis) on lower right)
What's under that electrocap stack?
Just the chassis...
What are you building there? I just bought turret strips for a Hoso 56 build... The ones in the pic look cool with the way you mounted them. Care to tell where to get them?
roberto
Re: dc for the heaters
Post by roberto »
Stevem wrote:if a amps layout is right then simply biasing up the filaments with about 45 volts of dc works just as good as running them on straight dc without the work of doing such!
^ this is what I always do.
