Amp making guitar pot scratch?
Re: Amp making guitar pot scratch?
(deleted)
I built a simple io box with the cap in it. It works great.Cliff Schecht wrote: Also why not place a DC blocking cap at the input? Somewhere around 0.022uF places your cutoff a decade below where the guitar even picks up (7Hz cutoff for an ~80Hz signal). I've done this on plenty of amps and it doesn't ever hurt the sound but it has stopped amps from shocking themselves (when someone is playing guitar and singing through multiple amps on the same power circuit).
I built a JTM45 that causes the same problem and different tubes didn't help. Besides the scratchy guitar pot, switching pick ups on my LP made an awful snap sound!
I suppose I could put the cap in the amp....
Scott
Someone needs to sell a pedal with just a cap in it - you could call it the "Scratch Remover".
Haha, brilliant Ken. You better patent that.Ken Moon wrote:Someone needs to sell a pedal with just a cap in it - you could call it the "Scratch Remover".
I put a cap off the input jack of every guitar I work on! My God it's like life insurance for less than a buck and when I think about it that blows my mind that a ant guitar you pay over 500 bucks for can't come with one!!
I started isolating all the jacks in my amps. Isolated input jack along with the B+ filter caps for the preamp to a grounding tab near input jack.
PI/filter cap, B+2 filter cap and B+1 main filter cap to separate grounding tab along with the CT's.
That has solved all the problems I've encountered with guitar buzz or hum.
I tried that cap off input jack and didn't get anywhere with that?
isolated jack
Delete. No worries.
M Fowler wrote:I started isolating all the jacks in my amps with B+ filter caps for preamp to grounding tab near input jack.
