bias-varying tremolo on a stand alone unit ?
Re: bias-varying tremolo on a stand alone unit ?
The version I have of the gretsch has an intensity control.I drawn a schmatic I'll try to find it.But I was thinkin it was implemented pretty much the same way fender did.Except one leg of the pot goes to ground instead of the bias circuit.
Big thanks everyone for the suggestions! I'll get back to the build after solving a noise problem on another build.
mat
Back to the build (standalone loop buffer/tremolo/reverb). I'm little confused how to set the order of the 3 circuits (2 tube reverb, 1 tube tremolo and dumbleator). What I would like to achieve is to have opportunity to bypass every 3 circuits. Should the reverb and tremolo be before or after the active loop ?
Any suggestions for the order ?
Thanks,
Thanks,
mat
Have you got a schematic you're working to so far?
- LeftyStrat
Personal opinion, and I've seen it done differently, but my choice would be tremolo, fx send, reverb. Here's my reasoning:mat wrote:Back to the build (standalone loop buffer/tremolo/reverb). I'm little confused how to set the order of the 3 circuits (2 tube reverb, 1 tube tremolo and dumbleator). What I would like to achieve is to have opportunity to bypass every 3 circuits. Should the reverb and tremolo be before or after the active loop ?
Thanks,
- Tremolo into delay can get some interesting rhythmic things going.
- Tremolo into later distorting stages can be neat because is more than volume manipulation, because it can modulate between clean and dirty, changing the harmonic content.
- Room acoustics are always the last thing in your signal chain, and reverb is a simulation of room acoustics.
Of course rules are made to be broken. I'm sure some interesting effects can be had by a different order. You could always have separate ins and outs and patch them however you wanted. With normalized jacks, you could have a default order that is broken when the jack is used.
Not yet. Actually I often draw only a layout by hand and build from there.tubeswell wrote:Have you got a schematic you're working to so far?
I was thinking Wallbangers suggestion (http://www.lynx.bc.ca/~jc/supro_s6616.pdf) of the Supro tremolo into dlator into Heistils 2 tube reverb.
Would the Supro trem tube then connect to the first stage of the D-lator ? Then the D-lator should be always on but I don't think that would be a problem.
mat
Good suggestionLeftyStrat wrote:You could always have separate ins and outs and patch them however you wanted. With normalized jacks, you could have a default order that is broken when the jack is used.
mat
