Interesting...so a socket shield can actually transmit noise/etc.. into a tube stage? I wouldn't think that there would be contact between the tube pins and the socket itself....and if the socket is not making contact with the chassis I'd think it wouldn't be part of a ground path.drz400 wrote:A) You should solder a piece of desolder braid from the tube socket to chassis, otherwise the socket shield can be an antenadehughes wrote:Well, I tried isolating the OT jacks from the chassis and moving the ground around to see if I could get things quieter (just in case this was the trouble...), and wasn't able to find a better ground point that was quieter. So, I assume the OT ground isn't the trouble.
HOWEVER, I noticed that when I stretch out my fingers on my right hand and touch both the OT casing and the tube socket shield for V1, there is a POP and then a really loud hummmm/buzzzzz until I remove my hand from either the tube shield or the OT casing, or just touch another finger to the chassis. What's that about? Touching the OT casing and then the shield for V1 shouldn't introduce noise/hum/popping into the circuit, should it? I have the tube sockets isolated from the chassis with rubber washers....and none of the tube socket pins are touching either the chassis or anything connected to the chassis.
This gets me thinking that maybe all this noise has something to do with the preamp ground and/or V1's interaction with the OT...
Am I correct in this, or way off?
THANKS GUYS!
B) The only way to figure out the ground path is to completely rebuild it correctly, the ground path needs as much thought as the whole circuit layout
What is it that makes the socket act like an antenna and then transmit into the gain stage?
Thanks!
