It is interesting.doveman wrote:Interesting ... what would that do? Is this possibly stressing the VVR?markr14850 wrote:I think it should be like this:
After the reservoir cap, the current flow is fairly smooth, and is mostly controlled by how much current the power tubes take.
Before the reservoir cap, the current is just pulses. These pulses last for just a small fraction of each power cycle, and have peak current of 5-10x the average current that you would measure after the cap.
If you'd like to interact with a visualization of this, download the Duncan Amps Power Supply Designer, change the rectifier type to full wave, run the simulation, and then display the current on the diodes, I(d1). To see the average current, display the current for the load resistor.
Anyhow, because the current is 5-10 times the expected value during these pulses, the instantaneous power thru the mosfet is 5-10 times higher than expected. That's pretty rough, and could certainly be the cause of your initial mosfet failure.
Great call Colossal!
