Any Naylor Superdrive love?
Gaz
Re: Any Naylor Superdrive love?
Post by Gaz »
Double
Gaz
Post by Gaz »
Triple!
dcribbs1412
Post by dcribbs1412 »
Thanks for the info Gaz
Darin
Darkbluemurder
Post by Darkbluemurder »
Gaz,
Thank you very much for that info.
Cheers Stephan
What is the purpose of the dual 500k pot for gain?
Go easy, I'm stupid.
roberto
Post by roberto »
That way you have simply one gain control for low gain and hi gain input, and a wider gain control on hi gain input.
Signals are in 180° out of phase, so you don't have any positive feedback effect possible.
Aha!
rhinson
Post by rhinson »
i've built several naylor sd60 type amps. (both the pre 96 and post 96 circuits). i have a few transformer sets to build these if anyone here is interested. i like the pre 96 circuit a lot, but both are good. i also add a a switch for an extra parallel treble cap for more upper mids if needed. the presence circuit is unique and is really cool. rh
dcribbs1412
rhinson wrote:i've built several naylor sd60 type amps. (both the pre 96 and post 96 circuits). i have a few transformer sets to build these if anyone here is interested. i like the pre 96 circuit a lot, but both are good. i also add a a switch for an extra parallel treble cap for more upper mids if needed. the presence circuit is unique and is really cool. rh
Thanks rhinson
what are the main differences in the pre and post 96 circuits? Any clips?
Here is a quick mockup of pre amp board what I can figure out anyway. Am I anywhere close?
Darin
rhinson
Post by rhinson »
Thanks rhinson
Darin
http://freestompboxes.org/viewtopic.php ... r&start=40
all the schematics for both are in this thread posted by the designer of the orignal circuits used by naylor (danny russell---a great builder). you can also find some good chassis pics if you search the gear page. rh
dcribbs1412
Thanks rhinson
great info
Darin
Darkbluemurder
I would consider using two separate gain controls instead of the dual pot. That would make it more flexible. You still can adjust them to the same knob position.
You will probably still have to compromise if you were to switch between modes during play.
Cheers Stephan
azatplayer
Post by azatplayer »
Say Bob, the 22uf on the presence pot, its an elytic right?
Was a bit confused with the handdrawn schems ive seen, he symbols across the board are for bipolars. Found some chassis pics, and sure enough looks to be an elytic on the presence pot.
Im gonna try this out on my express, see what happens..
rhinson
Post by rhinson »
yeah just a normal lytic. and it's part of the whole presence and p.i. circuit so you need to change the whole thing around it for effect. note the use of a nfb cap and not resistor. these are probably dark amps by some people's standards.
rh
azatplayer
Ahh ok, maybe I will wait till I build this sd60. Ordered an OT and choke yesterday. Looking forward to this. Bob, your preference on the the early one, that doesn't have the dual gang pot does it?
