Hot Rod Deluxe is dead.
billyz
Re: Hot Rod Deluxe is dead.
Post by billyz »
galtjunk wrote:I took the bells off and removed the copper tape.
I got down to where the leads were soldered to the internal wiring.
Everything seems to good up to that point.
I did not see anything like a fuse.
I ordered a new pt this morning so I'll just replace it.
Thanks,
If it had one that is where it would be. I just delete it and solder straight to the winding lead.
I think it looks like a ceramic disc cap.
Isn't it a thermistor that is used there? Or is it an actual thermal fuse?
Those look sort of like a metal can diode.
If you exceed the current rating it opens breaking the circuit.
It shouldn't be a one shot deal.
I would just remove it and solder the wires together.
billyz
Post by billyz »
Structo wrote:I think it looks like a ceramic disc cap.
The fuses inside the transformers I have repaired look like a black flat square with leads. It is buried inside the Transformer. Fender does use Thermistors these days and they usually are round disc looking usually Blue. but I have seen yellow and green .
galtjunk
Post by galtjunk »
New PT installed today.
All is well again.
Glad that fixed it but I wonder how it became damaged?
Doesn't seem like a simple face plant would break it.
galtjunk
Post by galtjunk »
I wouldn't think that a simple tip over would cause it either but it obviously did.
I tore the old pt apart and did not find anything visibly wrong with it but it is completely dead.
