M Fowler wrote:I do like the mojo custom CTS and matching mojo custom Alpha pots the best.
I usually purchase Alpha.....seems like "everybody" sells them, including Mouser.
They seem to get a bad rap, for some reason, on a lot of forums, but I do not know why. As mentioned earlier, how much difference do guys think there are in these two dollar pots........?
Guess I need to look into those 94/95 pots you guys mentioned.....never heard them discussed before.
diagrammatiks wrote:there's like barely any difference between all of the 2 dollar pots being made.
Is there ANY difference.? .....as far as "quality" and longevity.?
Some of the Bourns have a shaft so long that I have to take a Dremel to them.....or the knobs stick up off the face plate a long way.
What accounts for the nice torque (stiff) on some of the pots.? Is it just some lube on the shaft.?
Thank You
rotational torque of the pots is solely a function of the application that the pot is intended for.
for guitar/amp stuff...
generally guitar pots favor low rational torque - the faster the spin the better.
amp pots generally have a much stiffer turn.
most of the small size cts/alpha pots I've used featured a really fast speed turn meant for a guitar volume pot. In contrast, most of the NOS RV4s have a very stiff turn meant for more precise industrial applications.
yurka wrote:Anyone try the PDA24 series? They look nice, specifically designed for guitars and amps. They are a step above the solid shaft bourns pots from AES. Also very affordable, 2-3 bucks a pot on Mouser.
A word of caution with Bourns pots. The spec sheet shows
Manual Soldering
.....................300 °C within 3 seconds which is 572 degrees F. So set your soldering iron accordingly or you will burn out the pots.
I learned this the hard way after years of using CTS and Alpha pots which tolerate heat much better.
Also, do you typically snip off or drill a hole for the mounting tabs?
Where are you getting these?
I haven't ordered any but was curious if anyone had seen or used them? I'd read good reviews about the 16MM used in pedals and thought they might be good in an amplifier?
I do see them on Mouser. i.e. Mouser PN 858-P230-3FA25BR1K
Something I really hate about Mouser is that when you find a brand of component you want to use, they don't carry all the common values in that size or they just carry one or two values.
I realize very few places stock parts for tube amps anymore so it's difficult to find the voltage and power rating we need.
Structo wrote:Strange that BI doesn't make a 250K pot.
Alpha pots work fine for me.
Yeah, that's one of my issues with Mouser too. Another one is that you'll be researchig the hell out of one component, and find what you think you need, only to find out the part isn't what you thought it was. I had this happen with some Alpha pots. But I did learn what a detent was
They are "ok" the Audio taper is 2 lines not very smooth but compared to a CTS it starts working at about .5, a big improvement over the CTS starting at about 1.5. For my money the PEC military have the best smoothest taper and is about 4 or 5 lines plotted. CTS is next best. with 3. The Alphas and this are 2
I can post a plot if it sounds confusing, basically there is not a real curve but a real knee in the Bourns and the Alphas. I just got done plotting a bunch of audio tapers.
Manual Soldering
As far as the bourns pots go I've only used the square tab pots from apex jr. but I've found them to be quite good at handling repeated soldering and de-soldering while tweaking a design. I've had much better luck with these than alphas and strangely pec pots. I'm very careful to be fast and let them cool before hitting them with the heat again across all brands. The pec and alpha pots seem to not like repeated heat cycling like that, but the pec are darned nice for doing it once and doing it right. The only problem I have had with the bourns pots are the tabs becoming physically loose after after being beat on by repeatedly wrapping and removing soldered wires from them. The tabs still seem to make good electrical contact though and that's hardly a fault in the part, none of them are made for that sort of craziness.
Hey John, I'd love to see the plots of all of the the above if you have the time to post them. I'm a sucker for that stuff. Thanks in advance!
Here you go, any questions just scream. I only did 250KA for comparison
