Showing Off: 5C1 Champ Extra Fancy Grade
rp
Re: Showing Off: 5C1 Champ Extra Fancy Grade
Post by rp »
HTH wrote:try it with your 5C1 into the 5F1, might find something you like.
I think that's still illegal in some states.
Not a bad idea, I got the room for a chassis mounted resistor. What values did you use for an OD or did you just keep it the same as for a general line out? I used 2.6K and 470.
I'm thinking Crocodile Dundee: when someone shows up with their little OD pedal I can pull out my big bottle big OT 5C1 and say, "that's not an overdrive... that's an overdrive!"
