KT120 anyone?
LeftyStrat
Re: KT120 anyone?
Post by LeftyStrat »
Cliff Schecht wrote:I built a quad KT-120 bass amp recently and it was all the way loud. ~550V on the plates and each tube idled about ~75mA IIRC.. They get REALLY hot though, enough to where I'm installing fans in that amp once I get some time. Here's a gutshot before I put in the final e-caps.. I still owe you guys a proper build thread, maybe after the thesis is finished.. :shock:
[img:960:574]https://sphotos-b.xx.fbcdn.net/hphotos- ... 6730_n.jpg[/img]
Oh Cliff, I know you're busy, but when you get a chance you've got to tell us more about this beast. I remember the original thread where you were debating various topologies. I've been waiting for a followup ever since that thread.
Found the original thread:
https://tubeamparchive.com/viewtopic.php?t=16870
Cliff Schecht
Re: KT120 anyone?
Post by Cliff Schecht »
Yeah I plan on it, I have better pictures and a full schematic drawn up too. I have to finish my thesis and defend on the 18th, so after that I should have a lot more free time to post. Considering how complicated this thing is, it turned on and worked with relatively little hassle. I think it was more just myself being nervous about redplating such massive output toobs.. :oops:
Mark: I think 550V was plenty of HV for these tubes. Remember that I went with an ultra-linear output transformer so I'm running the screens at pretty high as well. I surely could have gone higher voltage on the B+ but the PT I used had over 1A of current available on the HV tap (!!!). I figured that was beefy enough to make a lot of noise. I might get in there and figure out a way to increase the drive to the power tubes though, I feel like it *could* be louder before clipping :D.
Cliff Schecht - Circuit P.I.
Kagliostro
Re: KT120 anyone?
Post by Kagliostro »
KT120 anyone?
No, GU-50 :D
russian military tube (the same of Telefunken LS50 german military tube and Telefunken EL152 german civil tube)
http://www.mif.pg.gda.pl/homepages/fran ... /EL152.pdf
HiFi guys have experimented this tube and guitar amp guy are experimenting it now :wink:
I know, is more like a ruggerized KT88 (after all, is a tube for tank use), but you can find it on the cheap
K
FYL
Re: KT120 anyone?
Post by FYL »
How about : "Dewey, Cheatem, and Howe"
They are their accountants or their law firm, aren't they ?
:D
Re: KT120 anyone?
Kagliostro wrote: No, GU-50 :D
Geez, you think that spec sheet has enough curves in it? 1000V. Wow!
These little buggers have special sockets and "hats!"
http://www.ebay.com/itm/2x-MATCHED-GU50 ... 3a7a601866
Holy cow! Going cheap! A pair of sockets might cost more than the tubes.
http://www.ebay.com/itm/2-x-TUBES-TELEF ... 3ccb3d263b
LeftyStrat
Re: KT120 anyone?
Phil_S wrote: These little buggers have special sockets and "hats!"
That is seriously bad-ass.
Re: KT120 anyone?
Theme amp. Paint Soviet green and it's made from metal plate scrap.
These things intrest me a little. I wonder what would happen if I swapped one of these Majors to those without the UL stuff.
BaBOOOOOM
Re: KT120 anyone?
Considering how cheap (including sockets), I'm tempted to build one into a display style head cab. That idea automatically gets derailed because I have no place where I can actually "turn it up." Even if I was home alone in my 33' x 16' living room, I don't think that would work. Then there is the matter of a cab to take that sort of power. Nope, won't be doing it.
Kagliostro
Re: KT120 anyone?
Original retaining sockets are effectively expensive
Tubes are very cheap
http://tubes-store.com/product_info.php?products_id=183
but you can get also only ceramic sockets on the cheap
http://valvole-audio.com/product_info_z ... assis.html
[img:500:400]http://valvole-audio.com/images/FU-50R.jpg[/img]
K
