Well done DocZ! Nice to see that you are sticking with it and, obviously, getting the hang of it.
Yes. If the tone and volume controls don't effect the character of the noise, it is getting "injected" somewhere down stream of those areas. The trem circuit is varying the bias on the second gain stage (and changing the gain) and isn't really getting involved in the signal path.
The noise is the crackly, frying bacon sound right? I didn't listen to all of your sound clips unfortunately.
Well...if I had to make a guess now, it would be the second stage plate resistor (250K if I remember correctly) or the sockets. Forgive me if you have already replaced that resistor and I didn't catch it in the thread.
You can replace that resistor with anything close that you have handy. The lower the value, the lower the gain of that stage. 56K to 470K would be just fine for a test. 1/2 watt recommended but higher OK. You could also sneak in a quick test with a 1/4 watt if you are desparate.
You are probably staring to see how handy the stethoscope really is. Diagnosing failures down to the component level takes all of about 3 minutes!
Dave O.
