OT on Dr. Z Stangray
live-i-evil
Hey guys, long time lurker and absolute n00b member with a question I was hoping someone could help me out with. I was wondering what output transformers the Dr. Z Stangray uses. I have a home built one coming in that could use a new OT. Since it's pretty much a clone of an AC30/4 I was thinking about the MM Woden clone or maybe even a JMI but the site says that it was designed by Mr. Fischer. With all the Trainwreck junkies here I figured someone would be able to help me pick one out. Toneslut, dynaco? Any help would be greatly appreciated. And I apologize if this is in the wrong forum.
Re: OT on Dr. Z Stangray
The Stangray uses 4k 4,8,16 40watt.
But I would just use the same OT as the Rocket which is the Dynaclone A-470-S 35w 4.3k 4,8,16
funkmeblue
ya, I would go with the dynaco a-470 as well. Triode electronics carries them
WHat does the tone control on the Stang Ray look like? Is it a rotary switch selecting coupling caps, or something else?
The tone control is not a rotary control. Has volume, tone and cut for front panel.
Thanks. I actually had the schem, and had forgotten.
The power stage is similar enough to the Rocket, that I woudl have to agree with the others - the DynaClone would be a great choice.
The preamp stage reminds me of the AC15 copy I have built (well, 3 of them actually), except that it has a more traditional tone pot instead of the rotary switch coupling cap selector (which I really like actually).
The BOM says Cin Tran 3229 PT and 3428 Choke, but I haven't had any luck finding specs. Any ideas?
Did Frank ever say what iron he used? Anyway, not knowing much about the amp, I'd go off of what it sounds most like. It looks like an AC-30, but there's a range of OT iron there. Seems like you could probably do it better than the original.
[edit]After looking at some gutshots and other info, it appears to me that the power transformer is the Trainwreck design. It's probably an Express PT with a 290 - 290 secondary. Using a 5U4B brings B+ down from where it would otherwise land. That leaves me suspicious that it's a TW style OT also...ymmv. hth
Some of the guys that have been building the Stangray clones have been talking with me since I own a Z Stangray and verify voltages as needed.
I have used it for 2 1/2 years straight for gigging without any problems and a fantastic tone throught open back 212 celestion blues. It was worth every penny I paid for this amp. Never touched any of my tubes either and some times that can be a good thing for us guitar players leave the tubes alone and play.
I now use my Rocket and 18watt Spitfire to get a lower stage volume with tone and some times those two don't mix well in a gigging situation.
I built this AC30/4 with a few modifications to bring it into modern times (higher filtering & a few other value tweaks) --> http://www.thegearpage.net/board/showth ... p?t=623882
I used this schematic as a guide --> http://www.blueguitar.org/new/schem/vox/ac34ef86.pdf
Anyway, I used the HTS-8093-1 OT and really like it. I excluded the tone control as well. I've built a few of these in the past and I think the tone control is not necessary. My Tone control is nothing more than a 3 position rotary switch to change caps to thicken it up or thin out the sound. I also have a 2 position bright switch (48pf & 330pf). These along with the Cut control is all the tone this amp needs. It's really a great amp with lots & lots of Vox character.
Back to the original question, most of the MM I've used sounds really good so I don't think you can go wrong.
Yeah, I am trying to sell this because there's a real sweet piece of Mahogany that just happens to have a couple P90's in it that I HAVE to have!!
live-i-evil
Thanks for all the suggestions guys, really helpful. I think I'm gonna go for the dynaclone A470S. I can't wait to get into this thing.
@fzfwyv, that is a damn purdy build and I would love to own it if I could get my money straight. sounds righteous as well.
One more note on the A-470-S dynaclone
I believe both Toneslut and rjguitars carries these varients as well besides Triodestore.
Do you run the OT ultralinear?
I do not but you sure could if you want.
live-i-evil
Sorry to resurface the thread guys but I was wondering what the advantages of getting a dynaclone version as opposed to the dynaco version are. There's a few sets of original Dynacos on eBay right now at a reasonable price, anything to keep me from getting them? Also, what difference would I see from running it ultralinear or not? Sorry some more absolutely noob quesitons and thanks.
The Dynaclone A-470S is an evolution of the Dyna A470, with more robust windings (the Dyna had a tendency to short turns with highish primary current) and PTFE-coated output leads (the originals had either cloth- or PVC-coated leads). It's IMO a more reliable OT.what the advantages of getting a dynaclone version as opposed to the dynaco version are.
Most have very short leads and come in unknown internal conditions - they haven't been tested by the sellers.There's a few sets of original Dynacos on eBay right now at a reasonable price, anything to keep me from getting them?
UL can be interesting with EL34's and shines with KT77's. I don't find it worth the bother with a quad of EL84's in Voxen clones.Also, what difference would I see from running it ultralinear or not?
