ACDCG400 wrote:sorry to bring back an old thread, but the 16mm pots are ok for amp use?
Depends on their application really, one cannot give you a blanket answer. Best thing is to look at their specs WRT your intentions.
Below is what I found quickly, but consult the data sheets for the ones you are looking at - there can be variations even from the same manufacturer,
best, tony
Alpha 16mm Solder lugs
Power Rating: 0,125 W log / 0,2 W linear
Voltage Rating: 150 V DC Audio / 200 V DC linear
Alpha 24mm Solder lugs
Power Rating: 0,25 W log / 0,5 W linear
Voltage Rating: 250 V DC Audio / 500 V DC linear
