Bass amp build
Re: Bass amp build
I just built a B15 preamp using Kevin O'Conners version using a 12AX7 and am running it into my Dynaco MKII mono block
dan...
[IMG:150:128]http://img381.imageshack.us/img381/3762/img0512lw8.th.jpg[/img]
[IMG:150:128]http://img381.imageshack.us/img381/5930/img0510bz5.th.jpg[/img]
sorry for the crappy photo's
if anyone is interested I can take some better ones
I also have a set of V4 transformers kicking around that I hope to eventually use for a bass amp build
Dan...................
[IMG:150:128]http://img115.imageshack.us/img115/6151/img0511ph9.th.jpg[/img]
http://img406.imageshack.us/img406/8706/img0509mf0.jpg
						dan...
						Re: Bass amp build
doctord02 wrote:I'm in the process of building a 4 x KT88 Hiwatt DR201 inspired bass amp myself.
i'd like to hear details about this build
Re: Bass amp build
Can you upload the pictures directly to the forum using the attachment thing down below?
I can't ever maximise those fileshack images because my anti spy software goes bonkers with there ads.
Re: Bass amp build
how's that I edited my previous post
does that work for you
Structo ??
Structo ??
Re: Bass amp build
Just using the KT88 schematics from Mark Huss' website and adapting what parts I have - a toroid dual secondary 325-0-325-0 PT stacked like the DR201. Hammond choke. A Fender surplus PS180 OT from Risson. Weber SLO chassis and head box with a custom faceplate. A bit of a hack, to be honest... Mix of freehand point to point and turretboard. A flatpack Triode transformer to get my bias voltage... Any thing specific you wanna know, just ask.jbrew73 wrote:doctord02 wrote:I'm in the process of building a 4 x KT88 Hiwatt DR201 inspired bass amp myself.
I only work on it in fits and starts and have been laid up recovering from surgery for the last week.
Re: Bass amp build
i am curious if you are doing any mods to the circuit. which preamp did you use?
						Re: Bass amp build
Using the '70's four input per Mark's suggestion, but only the normal channel hi and lo inputs to avoid using an extra tube. No mods per se, just deviations to accomodate parts on hand or easily available (ie, the toroid PT, and 220uF PS filter caps - one for every 2 100uF on the schematic basically).jbrew73 wrote:i am curious if you are doing any mods to the circuit. which preamp did you use?
I'll have a slightly more robust bias circuit, but other than that, I'm not intentionally altering the design. If it aint broke...
Re: Bass amp build
You could try and make it a dumbleland 300...
						Re: Bass amp build
is a schematic or layout available for the dumbleland 300?
									My Daughter Build Stone Henge
						Re: Bass amp build
I was surfing around on the web and found that the dumbleland 300sl was built around an SVT output and the Ampeg V9 preamp (late 70's guitar amp) with the addition of reverb.  sounds like it would be a really cool tone.
						Re: Bass amp build
Well... you twisted my arm.Ronsonic wrote:
That sounds like an awesome amp concept. You've gotta post pics.
A huge B15 is pretty much what almost any bass player needs.
