Perhaps this a semantical issue. A trimmer is essentially a small potentiometer. Can one assume that the only reason to use a trimmer in place of a potentiometer is convenience. Does the trimmer have any inherent sonic affect versus a pot. in other words are trimmers used also for their "character" in the sound chain, or is it still a matter of pure values that dictate the sound.
ange
						Trimmer vs Potentiometer
Re: Trimmer vs Potentiometer
Aren't trimmers just set and forget, therefore no requirement for shaft and knobs?angelodp wrote:Perhaps this a semantical issue. A trimmer is essentially a small potentiometer. Can one assume that the only reason to use a trimmer in place of a potentiometer is convenience. Does the trimmer have any inherent sonic affect versus a pot. in other words are trimmers used also for their "character" in the sound chain, or is it still a matter of pure values that dictate the sound.
ange
- VacuumVoodoo
Trimmers are for seldom performed adjustments, usually their service lifetime is in hundreds of rotations vs. (good) potentiometers running into 20-50.000.
									Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Also the power handling of trimmer is small compared to most pots.
Of course everybody already knows this.
If just searching for a fixed resistor value a pot would work fine substituted in circuit until the desired value is achieved.
