Two Rock Shielded wire
Guy77
Post by Guy77 »
Does anyone what type of shielded wire they are using here?
This looks like a great wire to work with. This is the Bloomfield Drive that I had on my bench several years ago.
It has the shielded wire that can easily be worked with in order to wrap around a pots lug or buss wire without making a mess.
The individual strands are strong and do not break apart easily like RG174 and are much easier to work with than the shielded wires that have the shield forming a tight net than cannot be easily separated.
Pic attached.
Guy
Re: Two Rock Shielded wire
I've never had a problem with braided shield. I use a dental pick to unweave the strands, then twist them.
Guy77
Post by Guy77 »
xtian wrote: Tue Aug 05, 2025 10:31 pm I've never had a problem with braided shield. I use a dental pick to unweave the strands, then twist them.
Thanks, I will try that.
Cheers
Olomert Brever
Post by Olomert Brever »
Sluckey recently recommended the shielded wire RG-316 to me on this forum recently. I am loving it so far.
You only YOLO once.
