Laney AOR 100 Coupling Capacitor Value
760Joe
Post by 760Joe »
The ceramic Capacitor in c20 was bent over and sort of melted into the resistor next to it (R39) and the capacitor's insulation was falling off so I thought I would swap that out while I was doing all the electrolytic capacitors. I couldn't read the value on the existing component. The schematic lists a 47pf capacitor for c20. The larger ceramic capacitor is what was in that location physically. The capacitor on the right is the 47pf capacitor I got for a replacement. Now looking at it out I see 47 N. Is that nanofarad? Should I get a 47nf or put in what the schematic says?
Olomert Brever
Re: Laney AOR 100 Coupling Capacitor Value
Post by Olomert Brever »
47nF would mute the signal there. Is this the model with an impedance selector switch or does it have discreet speaker outs for each impedance? I have my own ripped schem of one here somewhere but IIRC the two are different.
You only YOLO once.
I suspect "N" is a tolerance value, not meant to be "nano".
Post by Stevem »
Some info.
Roe
Post by Roe »
c20 is 47pf snubber
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
760Joe
Post by 760Joe »
Thanks everyone for the input. I went with the 47pf.
Olomert Brever wrote: Tue Jul 29, 2025 12:29 am 47nF would mute the signal there. Is this the model with an impedance selector switch or does it have discreet speaker outs for each impedance? I have my own ripped schem of one here somewhere but IIRC the two are different.
This one has a selector switch.
