I built it in a 5E7T chassis and had to add the hole for the tremolo tube. I'd be happy at this point to hear oscillation, but can move them after the fact once I actually get some noise out of the circuit.Stevem wrote: ↑Sat May 31, 2025 11:00 am When you do get it up and running that speaker jack right next to the 6SQ7 might make for a oscillation problem.
Also unless I missed it I only see one speaker jack, so how as you have stated do you have it wired for 8 and 16 ohms?
Also in your post from Friday you seem to be confusing mill volts and milliamps .
The chassis has output jacks on either side of where I placed the 6SQ7. I have 8ohms to the jack on the left and 16ohms on the right with the common lead connected to both.
