Thanks Stevem
That seem Ok, I got some bigger resistors and have a pile of tubes.
Switch the fuse sounds good too.
If that's the damage, then back to play.
And Yoda it seemed like 1967.
Fender 600 champion reissue complete rebuild
Re: Fender 600 champion reissue complete rebuild
Stevem wrote: ↑Sat May 03, 2025 7:02 pm Those two resistors are in the heater / filament circuit burned because your 6V6 is now shorted and bad.
Also when that took place the amps fuse should have blown but it did not because it’s a crazy large 4 amp fast blow fuse.
All original Champs and Bronco’s use a 1 amp slow blow fuse which is what I would use.
For a replacement tube a would get a JJ brand from Euro tubes.
They are a little more like a 6l6 and will far better stand up to your Hendrix hours of playing.
OK
I made it worse, between 15 ,16 now both continuity to J10 but not 9.
And nothing between 7 and 18.
That is after I plugged in and light went out in 1/2 a second. I possibly got Black #7 wrong on hookup?
Thanks.
You do not want anything bigger then a 1/2 watt resistor there.
There that wattage because under normal conditions that’s all that’s needed and also do that they burn up when there’s a shorted output tube and no harm comes to the filament winding of the power transformer.
