Amp Diagnosis Help
Re: Amp Diagnosis Help
The reason for raising this is that one problem might mask another. A clean build that follows typical accepted practice helps to avoid this. I'm not disagreeing with the diagnosis. However, once you resolve that problem, don't be surprised if another becomes obvious. Good luck.
