Ha !
Will work on my own !
Thanks !
Bell & Howell Filmosound 179
jujudubluz
Re: Bell & Howell Filmosound 179
"less is more" mies van der rohe
jujudubluz
hi and happy new year ...
here we are - came up with this mock up :
single channel 5E3 à la 5E5 with a switch to parallel 15ay7
i really want to keep up with the chassis as it is : single input / single volume / single tone ...
do you see any mistake ?
cheers
ju
https://drive.google.com/file/d/1pLYKMU ... sp=sharing
cheers
ju
You don't want to leave the grid floating when you disconnect drive to one side of the input tube.jujudubluz wrote: ↑Wed Jan 01, 2025 9:58 pm ... came up with this mock up :
... a switch to parallel 15ay7 ...
Use a Single-Pole Double-Throw (SPDT) switch:
- Grid goes to the Center lug
- One Outer lug goes to Pin 2 as you have drawn
- The other Outer lug goes to a resistor (any value from 47kΩ to 1MΩ) that runs to Ground
jujudubluz
Hey !
Thank you a lot - I will update my schematic and keep you posted !
Thank you again
Thank you again
jujudubluz
Try it like the image below. This version implies Pin 7 of the Input Tube is connected to the switch's center lug.jujudubluz wrote: ↑Sun Jan 05, 2025 12:28 pm here is the updated schematic :
https://drive.google.com/file/d/1hUJZMl ... drive_link
jujudubluz
Thank you !
My mistake - get it ! Pin 7 is either connected to pin 2 or to ground.
Will update my schematic.
Thank you again
Thank you again
jujudubluz
