After building multiple amps all with the purpose of creating overdrive I thought it was about time I built myself a clean amp. And here it is! The Lancaster. Named after the bomber plane, simply because I named the last amp The Vulcan. 15W 6V6 two channel amp. One channel is based off of the Songwriter 30 preamp and the other is Fender based with some extra features and small tweaks.
I went over on the transformers, the Edcor OT is a 25W unit, the choke is for an AC30 and the PT handles the power so easily that the HT only sags by 7V flat out.
Tonally it sounds incredible, dead pleased with it. As you can imagine with those transformers the bottom end is huge. For once I feel no need to tweak anything, just need to enjoy playing it
