The reverb output of that Imperial looks to be permanently mixed into the signal path, it’s only the inputs to the reverb driver that get disconnected by the switch.
Tweed 5e3 PLUS! with reverb??
Re: Tweed 5e3 PLUS! with reverb??
I don't understand this. I saw one schematic directly switching the input to the reverb tank to ground but I'm not sure how the reverb transformer handles that?
I am also surprised that a subjet as obviously "of wide interest" as "how to put a reverb in a 5E3" still did not get more than finely spreaded information...
(yet I can understand the reasons for that - given that some builders make part of their business out of it)
Also, have you seen: https://el34world.com/Forum/index.php?topic=7957.100
Whoops, my memory of how that worked didn't match reality. I guess I don't understand why you couldn't switch the whole thing out. I'm probably missing something obvious...pdf64 wrote: ↑Wed Sep 08, 2021 8:34 am maxkracht wrote: ↑Tue Sep 07, 2021 10:55 pm
… there are production amps with similar arrangements that work fine and it takes the reverb entirely out …
SC200HB_pg1.pdf
From Hoffman Amps .sch files 5E3 with Reverb schematic.
NICE!!!
it's near I take for the experiment....
If I down the mix resistor I get better resouls.... I amb going to try DWELL POT!
Thnak! in a few minuts I'll have something!
