Hello everyone.
It has been over a year since I have been active here.
I have gotten rusty with amps and hardly get to tinker around much any more, so I am hoping to get some short cut advice. My YGM3 Tremolo doesn't work. Actually I bought it not working. The tubes are good so that can't be it. The pots are fine and the wiring seems to be all in place.
Question: What typically makes these tremolos die? Do caps fail, or is there something more sinister?
Thanks as always
Markus
Traynor YGM 3 Tremolo trouble
Markusv
.........Now where did I put it?
Re: Traynor YGM 3 Tremolo trouble
Welcome back! Yes, any electrolytic caps in the tremolo circuit are suspect.
Markusv
Thank you Xtian. Will check tomorrow. I suspect that would be a tremolo tube cathode cap?
Leaky phase shift caps are also a common failure mode.
Markusv
Thanks -- so the 3 caps in successive CR configuration?
Thx Martin
Thx Martin
