Varistor Characteristics for Magnatone Vibrato Circuits
Diablo1
Re: Varistor Characteristics for Magnatone Vibrato Circuits
Post by Diablo1 »
I went back and grabbed some more varistors, FR1039, FS308, and FS927.
The FS927 is labeled as 1mA at 80 volts, so I took a shot that it'll work.
Diablo1
Post by Diablo1 »
Can someone explain why some of the old varistors are rated with ohms resistance on the package, and not any voltage or current? I left some varistors on the shelf, because I had no idea about their V/I performance and if they were suitable for the Magnatone.
We're they perhaps thermistors?
Diablo1
Post by Diablo1 »
martin manning wrote:We're they perhaps thermistors?
Maybe they are thermistors. The reason I'm confused is that Workman parts are labeled FR or FS, and some are labeled varistors and some are labeled thermistors. For example, FS308 is labeled as a Varistor 1.0 Ma @ 110 volts. FS1205 Varistor .05 ma @ 80 volts. FS927 Varistor 1.0 ma @ 80 volts. FR1039 Varistor 1.0 ma @ 68V.
Most of the parts labeled FR, like FR191 show an ohm rating at a temperature e.g. 120 ohms @ 25C.
Do Silicon Carbide varistors also function as thermistors?
No, they are different. A thermistor is a temperature dependent resistor, and a varistor is a semiconductor. Both are used to limit surge currents, but a varistor does it by shorting (to protect against a voltage surge or spike), and a negative temperature coefficient (NTC) thermistor is typically used to limit start-up current by having a high resistance when cold, which diminishes to a low value when it is hot and passing normal operating current. FR191 is a PTC thermistor used in CRT degaussing circuits.
Diablo1
Post by Diablo1 »
martin manning wrote:No, they are different. A thermistor is a temperature dependent resistor, and a varistor is a semiconductor. Both are used to limit surge currents, but a varistor does it by shorting (to protect against a voltage surge or spike), and a negative temperature coefficient (NTC) thermistor is typically used to limit start-up current by having a high resistance when cold, which diminishes to a low value when it is hot and passing normal operating current. FR191 is a PTC thermistor used in CRT degaussing circuits.
Thanks for the clarification Martin. I wasn't sure if SiC also had temperature dependent properties that caused the resistance to drop with increasing temperature, and that allowed it to also function as a thermistor.
trobbins
Post by trobbins »
http://dalmura.com.au/projects/Silicon% ... istors.pdf
The link is a good reference for old tech SiC devices like the Workman parts.
The old maggie varistor is best referred to as a ceramic part, rather than a semiconductor, as it is the granular interface that dictates performance.
That ceramic can be manufactured in an optimised form for low resistance and highish NTC, and hence act as a NTC 'thermistor' as we know it nowadays, albeit a poor performer when comparing with modern day devices.
In its day, it was pretty much the only cheap non-linear resistive device and so it was optimised for many many applications - all of which have now been superseded by better parts or methods.
I guess it's better to say that varistors are voltage dependent resistors and thermistors are temperature dependent resistors. In fact they are both types of semiconductors.
Diablo1
Post by Diablo1 »
trobbins wrote:http://dalmura.com.au/projects/Silicon% ... istors.pdf
So, is it possible that some of the old Workman SiC thermistors could double as a varistor, and have the correct characteristics to work in a Magnatone circuit? Or are the thermistor electric characteristics way off what is required?
trobbins
Post by trobbins »
A varistor for a maggie has a very high resistance if measured by meter.
I inferred from the SiC article that a high NTC was achievable with low resistance devices - perhaps your 120 ohm measure part was of that type.
Unless the part is in a bag marked with a model number then the only way to tell what part you have is to do some testing.
Diablo1
Post by Diablo1 »
trobbins wrote:A varistor for a maggie has a very high resistance if measured by meter.
I have a few varistors that I bought from Warbler Muse, claimed to be Magnatone spec NOS. I measured the resistance as 14 meg-ohms at room temperature. I warmed one up by holding it near a light bulb, and as it warmed the resistance dropped down to around 8 meg-ohms. So, it is showing thermistor characteristics, but as you posted, the resistance range is very high compared to the Workman parts labeled as thermistors. So, it doesn't seem likely that the thermistors could be used as a Magnatone varistor.
Kagliostro
Post by Kagliostro »
I've a GEM (old italian amp) that uses the same patent used by Magnatone
no schematics where disposable, so I reverse engineered the amp and
draw one by myself (see attached)
Whell, the two Varistor are very different (in the aspect) from those you can
see in a Magnatone, looking to the image, someone is able to read the
colors on the varistor and read it ? I tried to do that, but I wasn't able
to achieve a result
K
The image is labeled as unknown component because at that time I didn't
know the Varistor vibrato circuit and didn't understand what it was
trobbins
Post by trobbins »
K, please double check all the circuitry close to the varistors, and indicate what the 'blue' coloured numbers mean.
Some of the parts do not appear to be in the correct place - especially the vibrato modulator tube, which shows a 4N7 cap bypass on the 82k, and a 680pf capacitive top arm feed (as that should be a resistor arm, as the bottom arm of the modulator is the two 47N caps). Also the varistor midpoint is shown being dc coupled to other stages.
Kagliostro
I was near sure that the schematic is drawn as the circuit is, but I'll chek it again
thanks for the advice
the blue numbers refers to the numbers you can find on the schematic in this
.pdf file (the patent), see fig. 3
K
Diablo1
Post by Diablo1 »
Also, your notation of cap values is written like they are resistors. That is confusing, as we don't know the units. For example 47K for a cap value or 10K for a cap value. How many microfarads or nanofarads or picofarads etc.?
