Hi-Gain SE
Re: Hi-Gain SE
Take a look at the attached file: split load and frequency shaping.
very interesting
Thanks for those notes Roberto. I am working my way towards implementing some of these ideas. In the meanwhile, I wanted to post some voltages based on the actual point to point build which has a 12at7 in V1 and 12ay7 in V2. I also pulled the tone stack and tried a typical Fender blackface stack without a slope pot, rather a 100k fixed resistor. I went back to the Merlin tone stack and preferred that for now. I did implement the RAW control. All in all a good sounding amp with some very useable tones. I do want to extend the headroom as well as get into more complex overtones in the gainey sounds. The layout represents what I might do on the next build instead of point to point. And in fact this is the next iteration of this amp with a proper layout.
802]http://i260.photobucket.com/albums/ii9/angelodp1/1801-25-Master-pin-swap2_zps00ab14d0.jpg[/img]
834]http://i260.photobucket.com/albums/ii9/angelodp1/565-redo-pin-swap-boostMV_zpsc9ea3845.jpg[/img]
p tp p
Here is the P to P build - don't laugh too loud… it works and almost no noise level on hum buckers. This was a rework of the original amp that was used in an editing system.
768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0439_zps1631388c.jpg[/img]
768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0438_zps7fcd7dda.jpg[/img]
Re: Hi-Gain SE
Very interesting stuffroberto wrote:Take a look at the attached file: split load and frequency shaping.
How are you calculating the corner frequency for 2nd and 3rd cases?
82k-22k
Ok I threw in the 82k/22k voltage divider at V1a going into the .02uf that leads to the gain pot. That knocked back the AC signal by 2/3rd I reckon. That did help significantly with the high levels I was getting. Going to throw in a 12ax7 and see what that feels like.
Similar issue I had prior, which led me to the 12AT7 in V1, I get high end oscillation when the volume pot gets rolled up with the gain pot up full. This could be a lead dress issue as this point to point has a lot of nasty wiring convergences going on.
Went back to earlier configuration with 12At7 as this voltage divider setup hanging in the air was no bueno. I will revisit this with the next chassis that has a proper board and avoids some of these lead dress issues.
A
A
It lives
Ok, she's up and running. Its a 4 gain stage Champ w/ boost and RAW and variable NFB . It operates on 12AT7 in V1, 12AY7 in V2 and then 6V6 and 5Y3. It goes form a great clean tone all the way to OD madness. Dime'd it with a Strat and a Tele and it has a wonderful breakup with feedback howl if you want it.
768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0457_zps101bcc29.jpg[/img]
768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0456_zps36619a46.jpg[/img]
768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0453_zpsb01d5aea.jpg[/img]
768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0452_zps15945406.jpg[/img]
Re: Hi-Gain SE
Nice Angelo, that old blue perf board is perfect for this project.
Swamp thing
Thanks Mark, its does have some similarities to the Swampthing circuit. Lots of fun and quite a range. I may get brave and pop in some 12ax7's tomorrow, maybe throw this into series oscillation. Try and get some clips up soon.
Re: Hi-Gain SE
I did some test piloting and I'm happy to report that this build has the goods.
It can only improve as fine tuning ensues.
Smokebreak
Re: Hi-Gain SE
Very cool amp! I'm looking forward to some clips. The split load shaping is really intriguing, too. More reading on the subject : http://www.ax84.com/bbs/dm.php?thread=297726
Re: Hi-Gain SE
Stupid question but, is the Raw control simply a NFB type control like a presence control without the capacitor?
That seems like a cool thing to be able to control the NFB.
I have a switch on my Dumble clone for NFB on or off.
Really opens up at lower volumes when the NFB is off.
Re: Hi-Gain SE
Raw control (in most amps) is a 1M or so pot between the ground return and the tonestack that effectively removes the tone stack from the signal path (when the raw control is dimed). It works by lessening the AC load on the gainstage that is the source stage for the tone stack, whereby the signal loses the RC-filtering (and the attenuation) that the tone stack would otherwise provide. Thus the signal becomes more 'natural' (or raw). This is quite different from a presence control which alters active NFBStructo wrote:Stupid question but, is the Raw control simply a NFB type control like a presence control without the capacitor?
