Tuning up a vintage SVT, any advice?
				nateflanigan
Re: Tuning up a vintage SVT, any advice?
It's been a bit but I thought it'd be nice to post an update.  It took me a while to order some replacement pre-amp tubes, get my scope back from a friend, order a dummy load etc etc.  After taking apart the chassis and taking some time to get familiar with it (the amp's a bit overwhelming when you first open it up) I found some problems.  The pre-amp was exhibiting really weird, poor frequency response.  I could amplify a 1k test tone cleanly but as I lowered the frequency the power went out the window and the wave form would break down with hardly any amplification.  This was occurring on both channels, so I figured the 6c4 cathode follower which is after the point where the two channels mix might be suspect.  Replacing the tube did nothing, but then I found a suspicious resistor in that part of the circuit (R45).  It had obviously been replaced at some point, it should be a 47k resistor, color codes can be hard to read but this really really looked like a 470 ohm resistor.  I pulled it out, it tested at 62k, weird, but I replaced it with a new 47k anyhow.  Seems all is well now, I can amplify from 1k down to 40hz at ~30v across the dummy load and get a clean sine wave on my scope.
				vibratoking
You fixed it!  Congrats.
				nateflanigan
Thanks for the hi-5 my friend.
Excellent! I have worked on a bunch of SVTs this year, and when they are right, they are awesome. When something is amiss, they are nothing special. Biggest problem is keeping good output tubes in place. I did burn ins with all of them and bias drifted a lot over the first 2-3 hours on all of them. It's an expensive affair to retube these, but having good outputs makes a huge difference in performance. I have had good luck with SED and surprisingly, the new Tung Sol 6550s. I actually liked the Tung Sols a bit better as the low end was tighter and cleaner than with the SEDs.
				nateflanigan
I've heard good things about the new tung sols, I'll have to try them out some time
