BUGERA 333 XL
SMPL
BUGERA 333 XL
Post by SMPL »
I loose the signal in this rig when it is switched to Lead/Overdrive. I checked the obvious fuses and tubes. I also checked to make sure all five relays were switching. The clean works great but need the Overdrive/Lead to work also.
I know this rig has likeness to the Peavey and is made by Behringer. I have the schematic but due to the hard to trace non tech friendly circuit boards I am having difficulty finding where the signal is lost.
Any thoughts would be appreciated!
SMPL
SMPL
BUGERA 333 XL
Post by SMPL »
I found the problem! A bad 1/4 watt. 100k dropping resistor R93 at V7. These rigs are not the most friendly to work on.
SMPL :mrgreen:
