One of my amp clients wants me to build a buffer/splitter--one in and three out. There are a couple of helpful starting points on the web, one of which is this design for a one in/three out JFET buffer:
http://www.muzique.com/lab/splitter.htm
That looks like a good start. However, if used to feed two or more amps, ground loops can form. So I'm wondering if I can use the transformer output setup on the enclosed schematic from a buffered A/B/Y box, but put them on the JFET outputs?
Anyone have enough experience with solidstate stuff to advise here?
JFET buffer help!
JFET buffer help!
Rich Gordon
ground loops
Hi,
You cannot use a transformer output setup on the enclosed schematic from a buffered A/B/Y box it will still produce a ground loops. Just lift the ground on your amplifiers and it will remove the ground loops.
Goodluck!!
Goodluck!!
Re: JFET buffer help!
The Suhr Mini Mix uses isolation transformers to avoid ground loops.
