ID 5E3 PT
angelodp
ID 5E3 PT
Post by angelodp »
Hi guys trying to determine what this PT of a 5E3 build is.
It reads 1155-1017 6050215
Build has a unconventional wiring setup and trying to determine what this PT is exactly.
We have a bad hum, suspect strange wiring?
Any help IDing this PT greatly appreciated.
Wires
2 heaters - green
5v to rectifier - yellow ( pair )
2 - rectifier - red pins 4&6
1- red/white to ground
1 - green/yellow to ground
1 - orange capped
2 - black - both to fuse output
1 - brwn/ white stripe - power switch
1 - brwn = also to power switch
[IMG:2196:1647]http://i260.photobucket.com/albums/ii9/ ... G_4623.jpg[/img]
wyatt
Re: ID 5E3 PT
Post by wyatt »
EIA Code=605=Lenco
It was made OEM for someone, maybe Victoria. I am told Victoria did used to (quietly) sell their iron to hobbyists. Don't remember ever seeing a Vicky with a universal voltage PT though, which is why it has the double wires (Brown & Brown/White; Black & Black/White).
wyatt
Re: ID 5E3 PT
Post by wyatt »
A little research brought up a thread right here at TAG...
http://74.220.215.222/~neampfes/ampgara ... d292f83f54
angelodp
aha
Post by angelodp »
Ok great thanks for the intel.
A
angelodp
No luck
Post by angelodp »
Ok been looking around and the Lenco sites does not produce anything. Any idea what those bwn/white and brown wires are tapped at? two black wires?
a
Ok moving on the amp passes DC onto my guitar, very scratchy. Same guitar on a Redplate -no problem. So we are getting some DC onto the guitar? Any suggestions? Bad cap ?
A
Re: ID 5E3 PT
Is there voltage on the orange wire? If not it is probably the shield which goes to ground.
angelodp
checking
Post by angelodp »
Hi Mark, we will check that
thanks
