Wire types, sizes.
cllvt
Wire types, sizes.
Post by cllvt »
In some of the reference materials I see "heavy buss wire" used for grounding, etc. What size wire would be appropriate for this use? I imagine that this is a solid wire?
Speaker wires ... what size should be used?
Thanks,
Chris
David Root
Buss Wire and speaker wire
Post by David Root »
Buss wire is traditionally single strand bare solid copper, but it doesn't have to be. In my amps I use 18 ga. stranded teflon insulated between stars in a galactic ground, and also from the final star to chassis. 18 ga. can handle 6 amps comfortably, which ought to cover anything going South in the average guitar amp.
Speaker wire--50W or less I use 16 ga. lampwire in combos (short length). Typically you're looking at 3-4 amps or so max, and 16 ga. is safe. In wiring a 4x12 half stack I use 12 ga. wire, even if the speakers' total rated load is only 100W, because there's a lot more wire involved and you don't need any more added resistance between OT and voice coil than is absolutely necessary.
