Power amps
Power amps
Hi all, I've got a modeling effects unit (POD HD500) and was wondering about building an EL34 power amp for it, thinking 2x 50W so I could run it in stereo or bridge for 100W, anyone seen any similar projects or thoughts on how I could go about doing this?
- Reeltarded
Re: Power amps
There are schematics around the web for making stereo power. Do you have to build it? You can buy a used Marshall for less money than the transformers, and tubes.
It's just a power section from the PI back, x2.
Re: Power amps
Here in New Zealand the price of tube power amps is pretty crazy, building will be substantially cheaperReeltarded wrote:There are schematics around the web for making stereo power. Do you have to build it? You can buy a used Marshall for less money than the transformers, and tubes.
Re: Power amps
I'd do a search of the database on Torres before you spend $4.95.jeremyb wrote:Hmmmmm http://www.torresengineering.com/do30to200waa.html
Torres tends to rework other peoples stuff in a super-cool-absolutelty-the-best-no-where-else-on-the-planet way, which does not always sit well with the reader.
Eric
Re: Power amps
Torres schematics leave more to imagination then reference.
Dan has a weird way of doing his schematics too, all cramped together. Also, he leaves off the PT/OT information and when asked he replies no tech support can be given.
Waste of $4.95
Post the schematic and see what I mean.
Waste of $4.95
- Reeltarded
Re: Power amps
Ahh of course.
I don't have any great ideas, but I know schematics of the Marshall stereo amps are out on the web. You just take 2 separately fused 50s or 100s from the PI back, or build a pair of heads with typical series loops.
I would have to look.. I don't think it'd really be cheaper, would it?
Re: Power amps
This is only mono but it's just a power amp with EL34's
http://www.ax84.com/static/corepoweramp ... ematic.pdf
Mick
Mick
Andy Le Blanc
Re: Power amps
use two 50w opt and a 100w pt, shared power supply
but it keeps thing simple, is it just for guitar or are you looking for some fidelity too?
lazymaryamps
